Maximus-RCU
UT, USA Status: offline
Chinook, just finishing her up. I posted pictures a few replies back. I don't know if you saw them. I balanced the plane tonight and was somewhat surprised. I used the big Irvine 1.50 which is about the same weight as the recommended O.S. 1.60. Ended up real nose heavy. Weird. Ended up putting my 5 cell 1400SC pack all the way back in the end of the tail under the vertical fin. Balanced where the manual says there. I had to make a little access panel on the bottom of the fuse. Worked ok though. Is the balance point indicated in the manual right? Also, how are the recommended control throws? Hoping the weather holds out so I can give her a whirl. How do the flaps help out on landings? Good I hope. How much flap is everyone using? Later for now, Maximus
