RE: World Models p-51(giant 80" WS)
Tower Hobbies
Logged in as Guest
  Printable Version
More Resources on the
P-51D Mustang - GS
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • Discussions on this Product
  • All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: World Models p-51(giant 80" WS)
    Page: <<   < prev  1 2 3 4 5 6 7 8 [9]
    Login
    RE: World Models p-51(giant 80" WS) - 9/15/2005 12:44:39 PM
    Ragz
    Status: offline
    Alan what prop did you use to break in the zdz 40? And what prop do you use now?
    _____________________________
    Anurag
    (in reply to SkyKnight)
           Post #: 201
    RE: World Models p-51(giant 80" WS) - 9/16/2005 3:18:35 AM
    SkyKnight
    Status: offline
    I used a Menz Ultra 19/10 for break-in. Now I'm running a Mejzlik 18\12. Good speed and descent vertical! I also use the SlimLine ShowTime pump system for smoke. Looks really kool with the smoke coming off the side of the fuse instead of underneath.
    -alan
    (in reply to Ragz)
           Post #: 202
    RE: World Models p-51(giant 80" WS) - 9/16/2005 5:34:25 AM
    Ragz
    Status: offline
    I was thinking of using a bambula 18x10 for break in and a APC 20x10 for regular flying. What rpms do you get now?
    Anurag
           Post #: 203
    RE: World Models p-51(giant 80" WS) - 9/16/2005 12:29:39 PM
    SkyKnight
    Status: offline
    I was getting 7200 with the Menz and now I get 8000 with the Mejzlik.
    (in reply to Ragz)
           Post #: 204
    RE: World Models p-51(giant 80" WS) - 9/16/2005 1:32:19 PM
    FBaity
    Status: offline
    Questions for the guys that have finished and flown this WM P-51:
    How does the two piece wing work, install etc?
    Is anyone running a retractable tail wheel assembly?
    How does this model compair to Top Flite 84" P-51?
    Frank Baity
    AMA 38026
           Post #: 205
    RE: World Models p-51(giant 80" WS) - 9/16/2005 5:04:15 PM
    SkyKnight
    Status: offline
    Mine is the second generation kit which features the new wing with flaps. It has 2 aluminum spars for the wing. The instructions provide for disassembly after use. I glued my spars into the wing (perfect fit) and then glued the wing halves together.
    I use the retractable tail wheel assembly from Robart. It works fine. However I opted to use pull-pull cables for both the rudder and tail wheel steering - servo mounted in the radio compartment with tanks, pump, batteries, etc. My first one used a rudder/steering servo direct connected to the rudder with the tail wheel on the bottom of the rudder. That servo stripped gears and stalled during flight resulting in a total loss. I never before and will never again use direct connection. Pull-Pull only!
    I can not compare to other kits. This is my first large warbird. I do know this one is not true to scale. It doesn't exhibit any bad habits and is pretty fast.
    My exhaust was custom made by Bold Mufflers. I know the TF version has a scale exhaust available by both Bold Mufflers and Keilo (?). I also tried a ZDZ 50 but the extra weight required counter balancing. I think the ZDZ 40 is a great combo for this plane. I think guys have used as much as a ZDZ 60 in some of them.
    Have fun Frank!
    (in reply to FBaity)
           Post #: 206
    RE: World Models p-51(giant 80" WS) - 9/22/2005 7:33:37 PM
    ravill
    Status: offline
    Hi guys,
    The two piece wings are bolted together.
    I am using the stock pull-pull rudder and it is working out pretty well for me.
    Here is the pic I promised!
    I am having a problem uploading pics.... I'll keep trying..
    Rafael
    RAVjets Demo team. All We Do Is Fly.
           Post #: 207
    RE: World Models p-51(giant 80" WS) - 11/3/2005 7:37:18 PM
    Educol-RCU
    Status: offline
    Help.... Any one have the stabilizer for the P-51 Miss america GS for Sale?
    (in reply to ravill)
           Post #: 208
    RE: World Models p-51(giant 80" WS) - 11/4/2005 5:59:55 AM
    Ragz
    Status: offline
    I have the stock mechanical retracts on my plane. This is the new version so they are beefier. Yet, the gears seem very weak and they swing the plane sideways a lot. I am thinking of replacing these with robarts. Any suggestions on which gear will fit? I reckon the Robart 550RS with struts and 4 inch wheels.
    Anurag
    (in reply to Educol-RCU)
           Post #: 209
    P-51D Mustang - GS
  • See User Ratings
  • Jump to:
    Google
    SITE MAP!   : :   FORUM RULES
    Kaango.com Classifieds
    0.578RCU2
