.40 size pattern ship - which one.
Tower Hobbies
Logged in as Guest
  Printable Version
Advantage 2x2 meter F3A Pattern - RTF
Seller:  dbarrym
Details:   $1,050.00   |  12/1/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Pattern Flying >> .40 size pattern ship - which one.
Page: [1] 2   next >   >>
Login
.40 size pattern ship - which one. - 10/18/2004 11:46:39 AM
SBR_RV
Status: offline
well iam thinking about buying a .40 size pattern ship and putting my 46.fx in it.
what do you guys suggest which has decent vertical perfomance and good/great flight characteristics (stable flyer as well).
       Post #: 1
RE: .40 size pattern ship - which one. - 10/18/2004 11:58:15 AM
team_singapore
Status: offline
i reccomend u get a seduction freestyle(kit) by EZ,or a beaton30/50 by EZ or a hyde away 30/50 they are quite lite,seduction litest
(in reply to SBR_RV)
       Post #: 2
RE: .40 size pattern ship - which one. - 10/18/2004 1:20:06 PM
pmr
Status: offline
I second what Team Singapore mentioned and if I may add, the MK Alliance, the MK Synergy and the EZ PILOT Seduction Streamline would also be good choice. Hope this helps.
(in reply to team_singapore)
       Post #: 3
RE: .40 size pattern ship - which one. - 10/18/2004 1:36:44 PM
Boogie
Status: offline
Widebody 40??
(in reply to pmr)
       Post #: 4
RE: .40 size pattern ship - which one. - 10/18/2004 3:09:19 PM
pattern_flyer_2004
Status: offline
if the kyosho majestic is still in production, I will strongly recommend it...
_____________________________
Jeffrey
(in reply to Boogie)
       Post #: 5
RE: .40 size pattern ship - which one. - 10/18/2004 9:51:33 PM
Erik Johansson
Status: offline
It all depends on if you´re in a hurry.
If not, then I think the upcoming Epsilon 40 from CA Models which will be released around newyear will be very hard to beat.
/Erik
(in reply to pattern_flyer_2004)
       Post #: 6
RE: .40 size pattern ship - which one. - 10/18/2004 9:56:12 PM
Jock
Status: offline
I'd like to ad the Javelin II and the Venus 40 from Great planes to the list.
My Javelin performs very good with an OS .46 AX
Regards,
Jock
(in reply to Erik Johansson)
       Post #: 7
RE: .40 size pattern ship - which one. - 10/19/2004 1:49:43 AM
Warren
Status: offline
I can second the Venus; great flyer.
Warren
(in reply to Jock)
       Post #: 8
RE: .40 size pattern ship - which one. - 10/19/2004 2:07:32 AM
SuperViking
Status: offline
The javillen II from cermark flys very good, in all respects I dont think you would go wrong with this choice.
(in reply to Warren)
       Post #: 9
RE: .40 size pattern ship - which one. - 10/19/2004 4:05:25 AM
Rendegade
Status: offline
Personally I'd go for either a beat-on or a Venus.
My venus is a rocket ship, capable of knife edge figure M's but then again it has a 61 in it
hehehe
The beat on's are very nice flyers but I would suggest that you go for the fx, we did one with a YS 63 in it, the prop you need to swing to get decent thrust makes the landing gear too long to retract!
ahahaha
(in reply to SuperViking)
       Post #: 10
RE: .40 size pattern ship - which one. - 10/19/2004 5:50:43 AM
jetmech43
Status: offline
Venus no doubt
(in reply to Rendegade)
       Post #: 11
RE: .40 size pattern ship - which one. - 10/19/2004 11:16:25 AM
team_singapore
Status: offline
i also reccomend the majestic but it was meant for a YS53.......so since u have an os,i recomend either a Mk alliance,Synergy or Ez seductions(free and stream)
(in reply to jetmech43)
       Post #: 12
RE: .40 size pattern ship - which one. - 10/19/2004 1:03:25 PM
SBR_RV
Status: offline
thanks for the replys!
well iam not in a rush and not, might do a search and see how i go
       Post #: 13
RE: .40 size pattern ship - which one. - 10/19/2004 5:34:42 PM
8178
Status: online
I assume if you are looking at 40 sized pattern aircraft you’re not interested in heavy duty competitive pattern flying. If that’s the case, it’s hard to beat the good old Tower Kaos 40 ARF. Cheap price and it has the positive bonus of using trike gear.
< Message edited by 8178 -- 10/19/2004 7:33:31 PM >
       Post #: 14
RE: .40 size pattern ship - which one. - 10/19/2004 6:47:35 PM
SunShyne
Status: offline
If its a 40 sized one id go for the Fascination. The seller has them here on RCU. Great price for a sharp plane. I like mine alot! I like it soo much I asked the seller to build one in a larger size. Good build, light weight, and the build is pretty straightforward. I like the pull/pull config, rare to see it on this size ship and this price!
Fascination
good luck
matt
< Message edited by DiabloKid -- 10/19/2004 7:08:44 PM >
http://www.SendTextMessage.net
Revver Bro #86
(in reply to 8178)
       Post #: 15
