ys 110 fuel line    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Manufacturers Direct Support Forum >> YS Engines Support >> ys 110 fuel line
Page: [1]
Login
ys 110 fuel line - 10/19/2004 3:35 AM
lcacing
Score: 106
Last Login: 2/19/2013
Status: offline
what size of fuel line do i use? the tank is going to be about 20" away, also im thinking on making my own
smoke system and "t" off the pressure line and adding another check valve, would this affect the
fuel pressure?
Hide Signatures
       Post #: 1
RE: ys 110 fuel line - 10/19/2004 8:38 AM
MustangAce
Score: 100
Last Login: 5/23/2013
Status: offline
While we're at it........can I just run a 3rd "filler" tube from the tank to a dot. How do I fill and depressurize?
Hide Signatures
(in reply to lcacing)
       Post #: 2
RE: ys 110 fuel line - 9/22/2009 9:29 AM
Hardy
Score: 100
Last Login: 4/23/2013
Status: offline
Set up the fuel lines as per the diagram in the FZ110 operator's manual. To run smoke use a smoke oil pump. To fill and depressure the ys system, put a tie and dot in the pressure line between the check valve and the fuel tank to depressure the system. Put a tie and dot between the engine fuel filter and the tank use this dot to fill the tank. When I finish flying for the day, I remove the the depressure vent dot and replace it with a fuel filter. This vents the fuel tank pressure and allows the tank to equalize keeping stress off of the fuel regulator system. Been doing this for several years on two different ys engines, it makes them easier to start the next time you go to the field.
Hide Signatures
(in reply to MustangAce)
       Post #: 3
Page:   [1]
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Engine Manufacturers Direct Support Forum >> YS Engines Support >> ys 110 fuel line
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.297RCU1
