Epoxy Thinning Techniques
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Tips & Techniques >> Epoxy Thinning Techniques
Page: [1] 2   next >   >>
Login
Epoxy Thinning Techniques - 10/19/2004 7:31:47 PM
tomcatman
Status: offline
I'm getting ready to glass a set of wings and I wanted to know what would be the best way to thin epoxy? Can acetone be used for this purpose? I happen to have a quart of it, that's why I ask. Thanks
Richie
_____________________________
AMA 323233
"KICK THE TIRES AND LIGHT THE FIRES!!!"
ICEMAN
       Post #: 1
RE: Epoxy Thinning Techniques - 10/19/2004 8:12:19 PM
jaka
Status: offline
Hi!
You should not thin the epoxy at all!
Methanol could be used for thinning but only very sparingly ...choosing the right epoxy means you don't have to thin it!!!
Forget the hobby epoxy like ZAP and the like...buy a more professional brand (24 hour epoxy) like CST.
Regards!
Jan K
Sweden
(in reply to tomcatman)
       Post #: 2
RE: Epoxy Thinning Techniques - 10/19/2004 8:19:02 PM
tomcatman
Status: offline
Thanks Jan!!! I will try my LHS for that product.
Richie
AMA 323233
ICEMAN
(in reply to jaka)
       Post #: 3
RE: Epoxy Thinning Techniques - 10/20/2004 2:16:01 AM
Flyboy Dave
Status: online
Richie....
....I used to do fiber-glass hand lay-up for a living. I wouldn't use any kind of
epoxy to glass some wings. Use regular fiber-glass laminating resin, or from
your hardware store....some "geneal purpose" resin. (same thing) Epoxy is
too thick, too heavy, too hard to sand, and too costly.
Do a search on fiber glass, and read up on some techniques.
FBD.
An engineer says.... "That won''t work".
A mechanic says..."Oh yeah, watch this".
"Old Age, and Treachery will overcome youth and skill".
Revver Bro #4.
       Post #: 4
RE: Epoxy Thinning Techniques - 10/20/2004 2:41:22 AM
Woodpile
Status: offline
Flyboy,
What do you think of the West system for doing wings and such? I have some handy and it seems very convenient with those self-metering pumps and all...
Thanx for the help...
Ed
There's a fine line between hobby and MENTAL ILLNESS.
(in reply to Flyboy Dave)
       Post #: 5
RE: Epoxy Thinning Techniques - 10/20/2004 2:43:50 AM
Flyboy Dave
Status: online
ED....
....I've never heard of the "West system".
Revver Bro #4.
(in reply to Woodpile)
       Post #: 6
RE: Epoxy Thinning Techniques - 10/20/2004 4:15:48 AM
tedster
Status: offline
I posted a glassing question in the warbirds forumn and received some good info. Here's the link
http://www.rcuniverse.com/forum/glassing_hatches/m_2245062/tm.htm
I am using EZ - Lam 30 and cutting it about 25% with denatured alcohol with .75 oz. glass cloth.
Good Luck!
TIA, Ted
       Post #: 7
RE: Epoxy Thinning Techniques - 10/20/2004 4:19:44 AM
Woodpile
Status: offline
Flyboy,
It's an epoxy/hardner system by West Marine, used for boats. The containers can be bought with self-metering pumps, you know, one squirt of resin to one squirt of hardner. can't make any mistakes that way. It's a little expensive, but good for the watercraft...
Thought you might have used it before...
Ed
       Post #: 8
RE: Epoxy Thinning Techniques - 10/20/2004 5:04:42 AM
26C4U
Status: offline
For foam parkflyers where weight is an issue, I glass foam fuses with my wife's old stockings or panty-hose (I just don't tell her) and water-based Sadoline polyurethane. At least 3 coats of the poly-U will do. You can even sand it with 200-grit. The finished product is one tough shell that won't let the foam disintegrate on impact.
       Post #: 9
RE: Epoxy Thinning Techniques - 10/20/2004 7:32:48 PM
Flypaper 2
Status: offline
Proper stuff is epoxy 'Finishing Resin'. About half the viscosity of normal epoxy and doesn't leave a sticky film after it hardens. I use a brand by Bob Smith industries. Spreads on with a playing card.
Gord
Dreamed I was a muffler. Woke up exhausted.
(in reply to 26C4U)
       Post #: 10
RE: Epoxy Thinning Techniques - 10/20/2004 9:15:43 PM
CafeenMan
Status: offline
Don't thin epoxy. Don't use epoxy glue. Use Epoxy Finishing Resin which is already low viscosity and doesn't need to be thinned. I have a full tutorial on my site about what to use and how to do it.
How to Apply Fiberglass Cloth
Work is what I do for the love of it. A job is how I pay for it. :)
Please visit AirfieldModels.com
(in reply to Flypaper 2)
       Post #: 11
RE: Epoxy Thinning Techniques - 10/21/2004 7:36:22 PM
jaka
Status: offline
Hi!
West systems epoxy is rather good but there are better (harder and more easily sandable) 24 hour Epoxy (finnishing resin) around.
Regards!
Jan K
Sweden
(in reply to CafeenMan)
       Post #: 12
RE: Epoxy Thinning Techniques - 10/21/2004 8:53:01 PM
tomcatman
Status: offline
CafeenMan...I just finally got around to checking out your tutorial on glassing wings....GREAT STUFF!!! What really impressed me is that you only used 1/2 ounce of resin on each side of the wing!!! The added weight is barely noticeable. Thanks again!!!
Richie
AMA 323233
ICEMAN
       Post #: 13
RE: Epoxy Thinning Techniques - 10/21/2004 10:41:47 PM
TOYMAKER
Status: offline
DO NOT thin epoxy.
It will shrink over time and it also weakens the chemical bond.
The best way to thin epoxy to make it flow or penetrate is to use a hair dryer or heat gun.
You will be amazed at how well epoxy flows and penetrates wood, glas or c/fiber when heated.
Heating it will also get it to set quicker.
Wayne G.
quote:
ORIGINAL: tomcatman
Richie
       Post #: 14
RE: Epoxy Thinning Techniques - 10/22/2004 12:34:56 AM
rajul
Status: online
The best way to thin epoxy is to buy finishing epoxy
Mike Marks
RCU Moderator
Aerofly Support Representative http://www.aerofly.com/index.html
