Whats the best way to break in a OS91DF
Tower Hobbies
Logged in as Guest
  Printable Version
BVM Super Bandit - ARF
Seller:  rc4mike
Details:   $4,500.00   |  9/1/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> Whats the best way to break in a OS91DF
Page: [1]
Login
Whats the best way to break in a OS91DF - 12/10/2001 11:28:32 PM
airspeed917
Status: offline
I had to buy a new OS 91 for my Byron F-16, I never broke in a D/F motor before. Whats to best way to break it in either on the bench or in the plane on the ground (with out overheating it,) since there is no airflow over the motor if the Jet isnt moving?
And if anyone is interested I got an incredible deal from TGA on the OS91 large head motor and the hurricane replacement fan.
$314.00 for the combo,, thats less than Tower Hobbies get for the motor alone..
       Post #: 1
miss quote - 12/11/2001 2:47:44 AM
airspeed917
Status: offline
Figures, a half hour after I posted this, TGA called me back to tell me they under charged me $100, I knew i was to good to be true
(in reply to airspeed917)
       Post #: 2
Whats the best way to break in a OS91DF - 12/11/2001 6:40:27 AM
JohnVH
Status: offline
Oh man, if that doesnt get you worked up, So far I have had a good experience with them, But I have not got my jet yet..Should be problem free from what I heard..
I put mine straight in the Jet, ran it a little rich, made sure it didnt get too hot. Ran it a bit then shut it off, it should have came with some instructions..
       Post #: 3
Re: Whats the best way to break in a OS91DF - 12/11/2001 11:27:46 PM
Jackjet
Status: offline
[QUOTE]Originally posted by airspeed917
[/QUOTE]
Hi Airspeed917,
I have run in 10 OS.91's-the first thing I do is disassemble the engine-make sure there is nothing in there that does not belong-then I clean it up real good with solvent-(carb cleaner and brake cleaner)-then I use red and blue Locktite on all the bolts EXCEPT the 6 cylinder head bolts-I use the Red L.T. on the front housing 4 bolts-Blue on the rear drum rotor housing 4 bolts-Red LT on the carb. throttle arm nut and the carb barrel retainer screw- Red LT on the 2 carb. mounting bolts.-then I dump in ATF to pre lube it. First run-I use Powermaster 15% and I add 8ozs. of Castor oil per gal.Open main NV approx.3 full turns-start it up-let it run rich for 1 min.-pinch the fuel line to lean it out some-do this 10 times-then go fly it-keeping it slightly rich all the time.I do the run in in the airplane with the fan on it.
Jackjet
_____________________________
Jack Jet Williams
Hesperia,Ca
       Post #: 4
head Bolts - 12/13/2001 3:18:02 AM
w0mbat
Status: offline
The last time I assembled my 91DF, I used blue locktite on the 6 head bolts - 2 flights later, by head came off in the air and down came the jet!!
Now I use red loctite and check them before each flight!
       Post #: 5
Head Bolts - 12/13/2001 6:04:06 AM
airspeed917
Status: offline
Hey Wombat, Funny you should mention that, thats the reason why I'm having to break in this new motor. Three of the six bolts came out in flight,The three remaining couldnt take the compression and the head lifted up and the force of the motor firing was directed out the side and took a hunk of the crankcase out. Luckily I was coming up wind and was able to deadstick it in.
I'm going to red loktite the s**t out of this one.
       Post #: 6
OS.91 head bolts - 12/13/2001 7:16:27 AM
Jackjet
Status: offline
Hi Pilots,
the only reason I don't recomend using any Locktite on the headbolts is because when I used it in the past on Rossi.81's and OS.77's ,the heat cycles of running the engine(s) would really lock them in the crankcase so tight that they would strip the hex head out of the bolt or they would twist off. Then you would have to use a EDM to get them out.I have found that if I properly torque them in even steps-they NEVER come loose anymore.And I clean the threads on the bolts and crankcase with brake cleaner. Hope this helps.
Jackjet
Jack Jet Williams
Hesperia,Ca
       Post #: 7
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.531RCU1
