Ed Smith
Joined: 12/29/2001 From: Brantford, ON, CANADA Status: online
Proptop, I have never owned a Viper Kit. In the interests of safety however I would consider the following. The Viper is an ARF designed and built for a .40 size engine. ARFs being what they are it is very likely it is not "Overbuilt". You intend to power it with a tuned pipe .52 size engine. As Dave says, reinforce the nose area, or the firewall may head out leaving the rest of the airplane behind. It would be wise to check the incidences of all three components, Engine, Wing and tail. If these are in conflict you could have a real tiger by the tail on it's first flight. Take a close look at how the control surface hinges are affixed, some have been known to pull out. Are the control linkages tight with no play? if there is play you will get flutter and anything can happen Any reinforcing and repairs that you do will add weight. This will put greater stress on the wing during flight. Is the wing structure adequate to hold up under the stresses you willl be imposing on it? Does the wing have a credible spar? Not just a piece of carbon laying flat under the skin, that is useless. The foregoing is offered purely to help you keep the airplane in one flyable piece. Remember, I you do have an accident, you have exceeded the power recommendations of the manufacturer. You will be on your own in the insurance department! Ed S
