Can you believe this flies?
Tower Hobbies
Logged in as Guest
  Printable Version
Ziroli Beechcraft C-45
Seller:  lennyh
Details:   $9,000.00   |  8/30/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Aerodynamics >> Can you believe this flies?
Page: [1] 2   next >   >>
Login
Can you believe this flies? - 10/24/2004 1:41:58 AM
psk560
Status: offline
A friend of mine built this awesome and unique rc plane. It's called the "spaceship". He can't remember the magazine he got it from but it is surely an interesting discussion in aerodynamics. Check out the video of it flying at: www.psk560.com
Craig
Click to see fullsize image.
Click for fullsize
       Post #: 1
RE: Can you believe this flies? - 10/24/2004 2:08:51 AM
Technito20
Status: offline
Wow...Hard to believe that it would fly. Is that a O.S. 40 or 46 LA? That thing must be extremely light weight for it's size. And what is it made out of? I'm pretty sure it's not balsa.
_____________________________
Going up is a choice, coming down is not!
(in reply to psk560)
       Post #: 2
RE: Can you believe this flies? - 10/24/2004 2:29:02 AM
Mike James
Status: offline
Cute...
The B-29 video on that site kills me. Not for scale purists, but hey... Looks like a lot of fun. The suprise rocket boost on the X-1 was cool too. I'm glad someone hosts videos such as these, so we can all see them.
Mike James
RC Design and Building - www.nextcraft.com
       Post #: 3
RE: Can you believe this flies? - 10/24/2004 2:33:34 AM
psk560
Status: offline
Believe it or not the "Space ship" wieghs around 2 lbs. It is powered by an LA OS 25. It is made up entirely of stick balsa. WOW.
Craig
(in reply to Mike James)
       Post #: 4
RE: Can you believe this flies? - 10/24/2004 2:59:43 AM
Technito20
Status: offline
Oh man. 2 pound, all balsa plane. With a 25. That's interesting. How does it handle the wind? It looks like the wind can easily take advantage of it.
       Post #: 5
RE: Can you believe this flies? - 10/24/2004 3:29:33 AM
psk560
Status: offline
The wind was straight down the runway today light and variable. I'm sure it would do great upwind but the downwind side could be interesting with the much smaller airspeed. LOL.
Craig
(in reply to Technito20)
       Post #: 6
RE: Can you believe this flies? - 10/24/2004 3:47:17 AM
Tall Paul
Status: offline
That's a verrrrrrrry old Roy L. Clough design from "Air Trails".
       Post #: 7
RE: Can you believe this flies? - 10/24/2004 4:58:24 PM
dick Hanson
Status: offline
yeh - I tried gliders made from the ends cut from foam wing cores
Some were 2" wide and a 12" chord- Just stuck pieces of balsa in rear for a "fin"
The design is completely stable -tho they wobble a bit like a Flash Gordon rocket--
And for purists --no the L/D is not all that good.
I am watching you
Libby
(in reply to Tall Paul)
       Post #: 8
RE: Can you believe this flies? - 10/24/2004 7:39:23 PM
Gremlin Castle
Status: offline
Not only does it fly it was designed as a free flight. I built one as a youngster back in the mid fiftys.
With the new miniture servos and programming it could be a very interesting flyer.
The free flight version was just a low speed crash when the engine quit.
       Post #: 9
RE: Can you believe this flies? - 10/24/2004 10:02:19 PM
micsrcfn
Status: offline
Hi psk560,
That plane was in RCM, @ the late '80's to early '90's. I thought about building it myself. But... Oh well!
Mic
       Post #: 10
RE: Can you believe this flies? - 10/25/2004 2:15:32 AM
Jim Thomerson
Status: offline
There is a long Roy L. Clough thread in the Vintage forum. A prolific designer of interesting airplanes.
Jim
(in reply to micsrcfn)
       Post #: 11
RE: Can you believe this flies? - 10/25/2004 4:28:39 AM
BMatthews
Status: offline
I think it was Skip Ruff that was "responsible" for the larger RC conversion and the article. If you compare the one in this video to the originals I see that the side wings and dorsal fin are not there. The dorsal fin was said to act like dihedral and would probably have controlled the Dutch roll you can see in the video. Also the flat side strake "wings" would provide at least a bit of lift.
Bruce-
Proudly wasting balsa since 1965.
Free Flighters go that extra mile........
(in reply to Jim Thomerson)
       Post #: 12
RE: Can you believe this flies? - 10/25/2004 2:32:19 PM
Dsegal
Status: offline
You are correct, it was Ruff who did the "Martian Spaceship". Part 1 of his construction article was in the August 1991 issue of Model Builder magazine.
Dave Segal
(in reply to BMatthews)
       Post #: 13
RE: Can you believe this flies? - 10/25/2004 6:52:39 PM
DesignMan
Status: offline
I have had the pleasure of watching Skip fly his Spaceship. He had built one, and then when MB wanted the article, he had to build a second one! Skip also published a beautiful twin rotor Gyrocopter. The sexy lady on the cover is his charming wife, Deb.
Really nice people. Skip is a fireman working for Taft, California.
Larry Renger
Think S.M.A.L.L., y'all.
(in reply to Dsegal)
       Post #: 14
RE: Can you believe this flies? - 10/27/2004 4:35:32 PM
boberos
Status: offline
After seeing the video by psk560, I am amazed.
It appears to fly like a flying wing, & stable right down to stall speed, perhaps below. Can anyone explain the aerodynamics?
BTW, Bill Northrop still has plans for this one.
Gotta dig ot my M.B. mags.
Bob G
(in reply to DesignMan)
