RE: Curare 60 - Build    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Pattern Universe - RC Pattern Flying >> Classic RC Pattern Flying >> RE: Curare 60 - Build
Page: <<   < prev  1 2 3 [4]
Login
RE: Curare 60 - Build - 9/22/2012 12:06 PM
David Gibbs
Score: 100
Last Login: 4/9/2013
Status: offline
I recently built from the Eureka Aircraft short kit. Overall a good way to go now the MK kits have all been spoken for. Given you have a bit of building experience, grab the parts listing / drawings from Eureka and spend a few minutes working out which bit is which (reasonably intuitive, but parts are not marked!), it is well worth it.
A few more pictures and a bit more information here: VPA - Gibbo Build
Click to see fullsize image.
Click for fullsize
Click for fullsize
< Message edited by David Gibbs -- 9/22/2012 12:43 PM >
_____________________________
Facebook: Talking F3A Australia
Web: vicpattern.org.au
Hide Signatures
(in reply to N1EDM)
       Post #: 76
RE: Curare 60 - Build - 11/15/2012 5:51 AM
DESERT RATT
Score: 105
Last Login: 5/23/2013
Status: offline
Howdy Guys,
 I just picked up a Curare this evening. This looks bigger than a 60 size plane, Did they build a bigger one?  It has a fiberglass fuselage with foam core 2 piece wings with an aluminum joiner. It has not been completed as the guy that had it passed away and another guy ended up with this plane. The gentleman was setting it up for a OS pumped 120..
 Is there any information available? I've read most of the old post but none with wing span, length, Weight, balance position and control surface measurements.
 Any information is much appreciated.
Ratt
< Message edited by DESERT RATT -- 11/17/2012 2:03 AM >
Hide Signatures
(in reply to David Gibbs)
       Post #: 77
RE: Curare 60 - Build - 11/15/2012 7:16 AM
Rendegade
Score: 105
Last Login: 5/24/2013
Status: offline
PICS!
It''''s easy to fly, just throw yourself at the ground and miss!
Hide Signatures
(in reply to DESERT RATT)
       Post #: 78
RE: Curare 60 - Build - 11/15/2012 8:17 AM
doxilia
Score: 136
Status: offline
Mmm... Not having seen it and if I was a betting man, I'd say most likely not a Curare.
It's just the catch word for any pattern classic these days. It's sort of like if it has anhedral in the stab, it's got to be a Curare...
Indeed, pics!
David
Hide Signatures
(in reply to Rendegade)
       Post #: 79
RE: Curare 60 - Build - 11/15/2012 11:02 AM
J Strong
Score: 100
Last Login: 5/11/2013
Status: offline
In the 64" wingspan and length both pretty close. Here's one of mine you can compare yours to.
Click for fullsize
Jamie
In Bama
Hide Signatures
(in reply to doxilia)
       Post #: 80
RE: Curare 60 - Build - 11/15/2012 5:33 PM
dphill2
Score: 100
Status: offline
Here is my latest with a flat stab and the third wheel in the back !!
Dave..
Click for fullsize
Hide Signatures
(in reply to J Strong)
       Post #: 81
RE: Curare 60 - Build - 11/15/2012 6:01 PM
J Strong
Score: 100
Status: offline
Can't wait to see that taildragger go, and just love that main gear. It looks really cool compared to the straight legged conversions I've seen that one looks almost as good as the trike gear, but NO hassle with steering, or grass fields .
Jamie
In Bama
Hide Signatures
(in reply to dphill2)
       Post #: 82
RE: Curare 60 - Build - 11/16/2012 12:17 AM
dphillips3
Score: 100
Last Login: 5/22/2013
Status: offline
Looks good Ol man! You still got it You must have forgotten how the wings were done. lol
DP#3
Click for fullsize
Hide Signatures
       Post #: 83
RE: Curare 60 - Build - 11/16/2012 12:33 AM
J Strong
Score: 100
Status: offline
Dang, lil Dave, heard you can't come for the weekend, bummer
Just think of all the contest you'll get to go to when wez all in nursing homes got to raise the Family before ya play .
I'll fly some for ya, he he he
Jamie
In Bama
Hide Signatures
(in reply to dphillips3)
       Post #: 84
RE: Curare 60 - Build - 11/16/2012 1:06 AM
dphillips3
Score: 100
Status: offline
Yeah well, sometime life comes first.
Think about me when it comes up on the pipe coming out of the split S on the turn around!!!
And Yall better bring some wood back to Bama!!!
DP#3
Hide Signatures
       Post #: 85
RE: Curare 60 - Build - 11/16/2012 2:11 AM
dphill2
Score: 100
Status: offline
Same drive way 35 years later !! and what this old man stuff young buck !!
That was a Tipo anyway !!
DP2
Hide Signatures
       Post #: 86
RE: Curare 60 - Build - 11/16/2012 4:59 AM
DESERT RATT
Score: 105
Status: offline
Thanks guys. Ill get it out tomorrow and take a couple of pics.
I appreciate your help.
Hide Signatures
       Post #: 87
RE: Curare 60 - Build - 11/18/2012 5:22 AM
DESERT RATT
Score: 105
Status: offline
I added a few pictures for Y'all. Thanks for your help.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 88
RE: Curare 60 - Build - 11/18/2012 6:39 AM
doxilia
Score: 136
Status: offline
Ratt,
As I suspected, not even close to a Curare as you can see. This plane was designed and developed 20 some years later. It was designed for turn around and is indeed setup for a piped 120.
I know this plane as I've seen it before but the name escapes me. I want to say Typhoon but not quite.
David
Hide Signatures
       Post #: 89
RE: Curare 60 - Build - 11/18/2012 8:04 PM
DESERT RATT
Score: 105
Status: offline
I seen the difference right away, But thanks David. If you happen to remember the name I'd like to know it. I didn't get into Pattern ships and flying until a little over 10 years ago. Then with the years I haven''t flown I'm out of the flow of Radio Control period. Everything has changed..
Hide Signatures
       Post #: 90
RE: Curare 60 - Build - 12/10/2012 7:06 PM
Mvelez
Score: 100
Status: offline
Hello Everybody:
where can I get a new kit for a Curare? How big is the difference in cost between an old vintage, original kit, against a new kit?
thank you!
Marcelo
Hide Signatures
       Post #: 91
RE: Curare 60 - Build - 12/10/2012 8:23 PM
doxilia
Score: 136
Status: offline
Marcelo,
As they say, an original MK Curare 60 is priceless.
It is not a very difficult plane to build though if you have some kits under your belt.
The trickiest part is getting the stab to wing relationship right and getting the anhedral stab bang on. Models with anhedral stabs are trickier to align than models with flat or airfoiled stabs with no anhedral or dihedral. You really want to install the stab last once the wing and fuse have been squared up.
Going with foam core wings and stabs ought to also make for a truer model.
David
Hide Signatures
(in reply to Mvelez)
       Post #: 92
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.907RCU1
