sfsjkid
CA, USA Status: offline
I think both points of view in this thread are correct. Most, if not all manufacturer of nicads will tell you that voltage is not a good indication of charge in the battery, yet using an ESV gives me an indication of the state of charge. No, I cannot tell the state of charge if told the pack is at 5.060 volts. However, knowing that I charged my, say, T-34 the night before, starting the begining of the day at 5.440 volts, hitting 5.060 volts after about 4, 10 minute flights, I know I am still safe to fly for about 6 more flights, with this particular plane. Putting my this plane on the discharger and noting the time remaining, comfirms what my voltage readings, and my judgement is telling me. So what I'm trying to say is, while I am measuring voltage, which in itself is meaningless, given everything I know about a particular plane, and how I prepared it, what I'm actually doing is getting a sense for the actual current remaining. I don't know about other clubs, but ours requires a voltage check before each flight. I've noted that people have different methods of coping with the go, no-go decision, some charge immediately after going below 5V, others charge before each flight etc.. Seems to work given the fact that there are few planes lost to bad batteries.
< Message edited by sfsjkid -- 10/26/2004 6:31:45 AM >
