Flying Geezer
KY, USA Status: offline
OK, I'm in. The corelation between battery voltage and state of charge is not a myth. It takes a little knowledge to use it correctly because there are factors to be considered. For example: a quarter scale plane with two 1400 mAH packs reading 4.9 volts has a substantial amount of current delivery left. A 500-800 mAh pack at the same voltage in the same aircraft is a plane I wouldn't want to fly. In addition to being aware of the batteries capacity, (tested for capacity every couple of months), the loaded voltmeter should be connected and watched for 30 seconds or so, to see if voltage is fading. It's not an absolute measurement of capacity, but it defines a safety range if you know what you are doing, and the condition of your batteries, and you are astute enough to provide enough excess battery capacity for the airborne system you are flying. It's not perfect, but the corelation of loaded battery voltage, and remaing charge is NOT a myth. I don't care who says so. NOW, let me have it! "You can lead a horse to water, and you can make him drink, but it's really tough to get him to rinse out the glass."
_____________________________
Flying Geezer Hughes RC
