Mike01
Joined: 12/29/2003 From: Brooklyn, NY, USA Status: offline
Geezer, Because monitoring voltage as a curve....seeing what it is at rest, then when you apply a load, and watching it change over time can indeed be used to approximate remaining capacity, if you know what to look for. Just measuring voltage when your plane lands, even under load, doesn't tell you squat. It's like the voltage display in your radio...when you first turn it on, it usually gives you a high number, regardless of state of charge...then over time, you watch voltage go down...if it goes down slowly, good, if it drops rapidly, bad....but the point is...you are watching it all the time. Hangtime, Short answer...I don't check voltage. As I said, I'm pretty good at knowing the state of charge. If I'm uncertain, I swap batteries and discharge to verify what I thought...whcih in turn teaches me to guess the state of charge all the better. But remember that in my post where I asked BillS to tell me the capacity of my RX pack, I gave him two figures, one for voltage at rest, and one for voltage under load. Voltage under load is fairly useless too, if it's a small load applied for a very small amount of time.
