sfsjkid
CA, USA Status: offline
Bill, our club has a rule that requires a voltage check before each flight. I would do this anyways, and also afterwards. As everyone has mentioned is not the prefect method of measuring state of charge, seems to work for the most part as I don't hear many battery stories at the club. As for a RX battery checker in the TX, well I have one in my 9Z and use it religously. But I'm thinking you want one that sends real time information? That would be cool if it had real time logging capabilities, but have a feeling that it might be overkill, IMHO, and may give a pilot a false sense of security. A battery check just before the flight may give a good voltage indication, but in flight as the loads on the servos increases, may quickly discharge the batteries to nothingness, especially if one of the cells is marginal. I usually remember the discharge characteristics of each of my planes, and periodically discharge them at the end of the day. In this way, I know how many flights I had, and how much charge I had left. As for 600 mAhr batteries, I have them in the most of my planes, while other have 1000 and still others have 270's. Just depends on the plane. I've been able to get 10 flights or more, on the 600's depending on the plane with plenty of reserve, as measured on the discharger. Yet, on my 1/8th scale buggy, 600, would only be good for a couple of runs. Additionally, I must add that fast charging before a run will probably work most of the time but may bite, if you have a bad cell. Sorry for getting long, but in essense, I feel most secure by checking voltage before and after a flight using a loaded meter (for 30 seconds or longer, I might add), and knowing each of my battery packs.
