AmirN
NV, USA Status: offline
I've cut upwards of 120 cores, from small, skinny panels to 30" cords and nearly 60" span panels. The Feather Cut wire is sensitive to heat and not all that strong in tension. Tears too often, especially with the longer bows. I switched to Inchonel and it's stronger and tolerates heat ranges far better. Very predictable and precise. Haven't had one tear yet. There is a heat range along which you can get a great cut with all the angel hair, but you can control the speed of the cut while maintaining the same quality. Inchonel is very good at this. It's working great for me......The Feather Cut wire gets more difficult to work with as the bow gets longer too. I get mine from CST. It's been very good and solid even on a 70" bow, which has pretty good tension on it.....I've cut 1 lbs. foam, pink foam, Spyder foam, etc....Very happy with Inchonel :-) Have fun, Amir
