RE: Super Tigre G90
Tower Hobbies
Logged in as Guest
  Printable Version
Skymaster F-5 Turbine - ARF
Seller:  Gripenflyer
Details:   $2,300.00   |  11/17/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Tachometer Readings >> RE: Super Tigre G90
Page: <<   < prev  1 2 3 [4]
Login
RE: Super Tigre G90 - 9/11/2007 7:35:53 AM
Robert Groves
Status: offline
thanks nick
Ill get bthe new readings to you as soon as I can.
Moving house this weekend.
(in reply to NikolayTT)
       Post #: 76
RE: Super Tigre G90 - 9/11/2007 7:53:20 AM
Robert Groves
Status: offline
Nick
I have never heard of an OS A5 plug??
I am going to try the OS 8 four stroke plug in the ST90.
Do you have any details of the A5?
Rob
(in reply to Robert Groves)
       Post #: 77
RE: Super Tigre G90 - 9/11/2007 4:16:25 PM
w8ye
Status: online
http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXCB29&P=ML
_____________________________
Attended the CutFinger Institute of DirtNap University for years but never did graduate....
Club Saito Member #7
Original AMA #31261
       Post #: 78
RE: Super Tigre G90 - 9/12/2007 1:12:43 PM
Robert Groves
Status: offline
HaveBlu
12600 with a 12x8 APC.
Are you using stock muffler ?
Plug?
Fuel?
I have an ultrathrust muffler on and getting 12300 peak.
Thanks for the info
Rob
(in reply to HaveBlue)
       Post #: 79
RE: Super Tigre G90 - 9/12/2007 1:17:08 PM
Robert Groves
Status: offline
thanks w8ye
(in reply to w8ye)
       Post #: 80
RE: Super Tigre G90 - 9/21/2007 2:57:24 AM
flipstart
Status: offline
Current G90, with stock muffler, OS A8 plug
Wildcat 15%, 18% oil, 80/20 syn/castor
13/6 TF power point
13,200 peak, 12,900 to fly
Have run about 9 tanks thru engine, 4 on test stand
82 degrees, 80% humidity
Big difference when I switched from St plug to the OS #8.
Wonder how much gain one could expect if you removed the baffle, mine is loose anyway and rattles.
Engine is still breaking in and seems to get better with every tankful. the 13/6 may be too small a prop if rpm keeps increasing.
REAL AIRPLANES HAVE MACHINE GUNS
       Post #: 81
RE: Super Tigre G90 - 9/22/2007 2:24:04 AM
flipstart
Status: offline
Failed to mention that I have also cut off the manifold pipe about 1/2" so it does not stick so far into the muffler - should help reduce restriction further. The baffle is removed, I plan to fly next week with the above changes-will post results.
(in reply to flipstart)
       Post #: 82
RE: Super Tigre G90 - 9/22/2007 4:39:00 PM
BillS
Status: online
What is the current wisdom on glow plug heat range for the ST 90.
Bill
       Post #: 83
RE: Super Tigre G90 - 9/22/2007 8:47:57 PM
flipstart
Status: offline
Bill-not sure about the current wisdom-but one of guys I fly with has about 30 years of using ST engines-he helped me with my G90-I was suing the ST glow plug on breakin and starting to have trouble. We switched to the OS #8, which he uses in all his ST engines, and bingo-like a completely engine, even before it was starting to break in. That is only plug he uses in his ST G90s.
(in reply to BillS)
       Post #: 84
RE: Super Tigre G90 - 9/25/2007 3:00:16 AM
BillS
Status: online
Thanks.
Bill
       Post #: 85
RE: Super Tigre G90 - 10/16/2007 2:43:52 AM
buzzingb
Status: offline
The Super Tiger engines seem to be able to take abuse and keep flying. Many engines will not tollerate abuse. I was very interested in trying the tuned pipe on this engine. Have any of you experimented with the pipe on this engine?
< Message edited by buzzingb -- 10/16/2007 2:46:01 AM >
Buzz
(in reply to BillS)
       Post #: 86
RE: Super Tigre G90 - 12/18/2007 4:52:33 PM
BillS
Status: online
Does anyone have rpm numbers for three blade props? I have an application that needs a three blade prop.
Bill
(in reply to buzzingb)
       Post #: 87
RE: Super Tigre G90 - 12/19/2007 1:54:45 AM
jeffk464
Status: offline
I had the same results putting a OS 8 in my gms 47 it upped the reliability 100%.
(in reply to BillS)
       Post #: 88
RE: Super Tigre G90 - 12/19/2007 4:38:59 PM
buzzingb
Status: offline
Bill I have seen a guy fly one with a 12X8 MS three blade on a 60 size Mustang with good results. He had a pitts muffler on but don't know if it made more power with pitts muffler or not. It reved up really well in the air and had good speed.
Buzz
(in reply to jeffk464)
       Post #: 89
RE: Super Tigre G90 - 12/19/2007 4:44:31 PM
buzzingb
Status: offline
My impression so far with the Super Tiger 90 is good. I don't think it can outpower all the other 90 size engines out there but it certainly can hold its own. It is cheap and built well and should hold up for the rest of your life with occasional bearing changes. Mine runs like a top with a 13X6. I want to try a tuned pipe but haven't gotten around to it yet.
Buzz
       Post #: 90
Jump to:
