RE: GMS Engine Tuning Problem
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> RE: GMS Engine Tuning Problem
Page: <<   < prev  1 2 [3] 4 5 6 7 8 9 10   next >   >>
Login
RE: GMS Engine Tuning Problem - 11/11/2004 2:10:17 AM
Wayne Miller
Status: offline
Hi XJet,
Wayne
(in reply to XJet)
       Post #: 51
RE: GMS Engine Tuning Problem - 11/29/2004 11:54:16 AM
Squid
Status: offline
I too have this problem. Running 5% nitro, 16% pure castor, rest Methanol. Dont want to up the Nitro, too expensive here. Started with the not being able to shut off problem and cutting at full throttle. Sealed the carb, fixed the cut off. Put the engine cuts down to not fully run in/overheating. Indeed after a couple more flights got it to run well. Then suddenly (after removing a shim to get more power), it ran like a pig, after peaking, it would cut if held vertical of splutter if ran a little rich. Also the main needle could be turned +- 1/4 turn without a noticeable difference. Fuel system checks out ok, no bubbles in the feed and no leakes under pressure. Just tried using some silicone tubing to further seal the needle (the o rings were lookin a bit worn, esp the outer one which doesnt get much lube). HAvent run it yet to see if it helped. I was also thinking maybe a cooler plug to compensate for the increased compression until I read this thread.
I shall investigate the holes lining up, and fix it if so (without drilling any nipples) and report back in a couple of days.
(in reply to Wayne Miller)
       Post #: 52
RE: GMS Engine Tuning Problem - 11/29/2004 12:55:50 PM
Wayne Miller
Status: offline
Hi Squid,
Thanks, I look forward to your report. Good luck!
Fly4Fun,
Wayne
(in reply to Squid)
       Post #: 53
RE: GMS Engine Tuning Problem - 11/30/2004 6:25:33 AM
cheechukranch
Status: offline
Wayne,
I've got a new GMS 32 for a combat plane. I have not run the engine yet. Should I go ahead and assume the thing will leak around the carb and muffler and seal these areas with red RTV?
Thanks!
       Post #: 54
RE: GMS Engine Tuning Problem - 11/30/2004 7:05:24 AM
Squid
Status: offline
Well, guess what guys, the hole in the brass insert was exactly half blocked by the carb body! Seems like they didnt pay enough attention when assembling the carb and they probably passed it on doing an air flow check (blowing through the hole) which would not pick up the restriction. This 'anomaly' has GOT to restrict the high speed running fuel flow!
I drilled out the hole only with a 1.5mm drill using the inlet nipple as a drill guide. If I had not promised to leave the nipple alone (!!) to determine if the this one mod made a difference, I would have drilled the whole thing through with a 1.8mm drill. Watch out for breaking the drill bit, I had mine snap off inside as the hole completed and the drill fell to the back end of the brass insert. MAnaged to pick/flush it out phew! Cleaning is very easy blowing through with some wd40 using the plastic tube extension into the holes. Remove the barrel before drilling and remember to backflush from that side afterwards, then use a strong light one side to check all shavings removed. Use a smidge of locktite on the nipple threads, needle holder threads and barrel retaining screw on reassembly.
For y'all out there with suspicious running motors, this is such an easy check to do. Remove the fuel inlet nipple with a 5mm spanner, shine a light in the hole and it will become immediately obvious if the hole in the brass sleeve is in alighnment with the carb fuel inlet or not, a 2 minute check.
Will run and set up the motor this evening, may not pick up the motor cutting, but should be able to see the motor leaning reaction to nose up test and needle sensitivity. Test flight report will only be available monday unfort.
(in reply to cheechukranch)
       Post #: 55
RE: GMS Engine Tuning Problem - 11/30/2004 7:10:23 AM
Squid
Status: offline
Cheech, if your motor doesnt cut smartly then the throttle barrel is fully closed, then you need to do this. If the motor is out of the plane, it may be easier to just do it anyway and save yourself future hassles.
On the muffler side, I did not use the paper gasket supplied, they always compress after a while and blow through or cause the muffler to fall off! Just a thin smear of RTV sealant is all thats required.
(in reply to Squid)
       Post #: 56
RE: GMS Engine Tuning Problem - 11/30/2004 1:44:19 PM
Spicoli
Status: offline
Wayne,
I think you are right.
I checked the inlet on 3 different carbs.Every one looked restricted to varying degrees.It looks like They pounded in the brass insert with the hole already in it and didn't check to see if the hole lined up.
One hole looked so bad I dont know how the fuel got through.It looked like the carb air intake hole when the throttle is set to idle.
I drilled all 3 of them out and will test them on combat spads this weekend [weather permitting]
All of the carbs came from engines with the silver muffler and with no fins.
You the man!
Kelly
(in reply to Squid)
       Post #: 57
RE: GMS Engine Tuning Problem - 11/30/2004 2:15:20 PM
Wayne Miller
Status: offline
Hi Squid and Spicoli,
Thanks for the update, I'm glad to hear that you were able to confirm the blockage. Did you drill out the muffler nipple, or are you going to try the carburettor fix first, then the exhaust nipple if required?
Also, you may want to review the "fix" post (number 38 in this thread) for the carburettor adj. - if you find a better method, let me know. By the way, if the engine hesitates when transitioning from low to high, I normally have to lean out the low speed adjustment for most engines. The GMS seems to like it better if I richen it a little instead - why? I don't know. You may want to also verify this with yours.
I'm anxious to find out how you make out.
Thanks so much for all your help.
Fly4Fun,
Wayne Miller
Edited for typo
< Message edited by Wayne Miller -- 11/30/2004 2:45:45 PM >
(in reply to Spicoli)
       Post #: 58
RE: GMS Engine Tuning Problem - 11/30/2004 8:50:24 PM
Spicoli
Status: offline
Wayne,
I drilled the carbs.I am going to leave the mufflers alone.They work great on my OS46FX's
       Post #: 59
RE: GMS Engine Tuning Problem - 12/1/2004 7:36:47 AM
Squid
Status: offline
Hi Chaps,
Had a good go at it yesterday evening.
I was able to simulate the leaning overheating problem quite easily in the garden so was able to do all the tests necessary yesterday. It appears my motor just cuts when it gets too hot (measured over 210deg C on the head!), so now to find the reason for the overheating.
It appears to be excessive leaning when the model is in a climing orientation. In its current configuration, this motor appears to be much more sensitive to this than others (eg Irvine) which I have. So lets see if these mods help at all:
1) Ran the motor with only the new hole in the brass insert, 1.5mm, needle more sensitive (could have been the sealing of the needle end with fuel tubing), no change to climb/leaning sensitivity.
2) Drilled out the exhaust pressure nipple to 2mm. No change in anything.
3) Drilled out fuel inlet nipple only to 1.8mm (brass insert hole still 1.5mm), needle the same, slight reduction in climb/leaning sensitivity.
4) Drilled out the brass insert hole to 1.8mm to match the fuel inlet nipple, needle the same, slight reduction in climb/leaning sensitivity.
5) Replaced head shim (total 3). Starting easier (less compression), no apparent loss of power, no change in needle or leaning sensitivity. (running 5% nitro at sea level, 24 deg C)
After all this, the excessive leaning was still a problem. but could be tuned sufficiently for flight, about 30% power loss in horizontal orientation when peaking in the verticle. Still not acceptable.
The one thing I didnt try was a baffled muffer. Im running the standard noisy instrument. This in conjuction with the previous mods would have helped the most I suspect.
My conclusion is that although these mods helped, they have not fully solved the problem in my case. I took another look at the fuel tank location and decided to relocate it closer. Previously, the tank centre was 8 inches (about 210mm) from the carb. I have relocated it to 6 inches (170mm). I ran out of light for testing, but am hoping those extra 2 inches will make a difference (!!).
       Post #: 60
RE: GMS Engine Tuning Problem - 12/1/2004 12:24:20 PM
Wayne Miller
Status: offline
Hi Squid,
Thanks for the input. With the tank that far back, I'm sure increasing the tank pressure from the exhaust will help.
By the way, I found that when I was relying on tank pressure alone, I only needed the back baffle (near the exhaust exit) show in the earlier post.
Again, thanks for your help, I'm sure one of us will find the problem and solution!
Fly4Fun,
Wayne Miller
(in reply to Squid)
       Post #: 61
RE: GMS Engine Tuning Problem - 12/2/2004 7:27:16 AM
Squid
Status: offline
Ran the motor again last night with the tank moved forward. That seemed to do the trick, only about 5% drop in power between horizontal and vertical orientations now which is acceptable. I guess the low muffler pressure due to lack of baffles combined with the rearward tank location was causing my leaning out blues. GMS really should fit a baffle, they are noisy without, and the running improvement would certainly be worth a few hundred rpm drop imho.
       Post #: 62
RE: GMS Engine Tuning Problem - 12/2/2004 2:19:37 PM
Flyer Freq
Status: offline
I don't think we totally have the problem solved yet, but we are close. I understand why many would believe there is a need for baffles in the tuned muffler, but it really shouldn't be necessary. The exhaust outlet is smaller than the typical tuned muffler. This is what offers the back pressure. My friends GMS has the new style muffler, and it has the same problem that you are attributing to the tuned muffler. I believe it is stricktly a carburation problem. I should have my friends engine to play with in a couple of weeks. I am not commenting, as I am, without first hand experience. I have one of the older GMS .47's, and it is an awesome engine. It has been run so much, you can't tell that the head was ever gold. Instead of the performance decreasing, it keeps getting better, and I have not removed any of the gaskets in the head. As for the noise, I agree that it appears the engine is noisey, but if you run a hose from the exhaust port to another muffled canister, so you get the engine cumbustion noise away from engine, you will find that most of the noise is coming from the propellor, turning incredible RPM. When my prop is turning 16,200 RPM, the prop noise is incredible. In the air, when the engine can really unwind, there are some undiscribable sounds that come from the plane, that I believe are the prop tips going supersonic. If I could run a bigger prop on this plane, I would, as this is a lot of punishment for the engine. But in that regard, I am in my 5th year with this engine, and it is still going strong. Each .47 should be capable of this performance.
Thanks Wayne, for putting this organized effort together to find the problem. It will pay dividends for all of us!
Andy
_____________________________
Lose not thy airspeed, lest the ground rise up and smite thee!
If you want to make God laugh, tell Him your plans
(in reply to Squid)
       Post #: 63
RE: GMS Engine Tuning Problem - 12/2/2004 2:21:47 PM
Wayne Miller
Status: offline
Hi Squid,
From reading your post, I wasn't quite sure whether you enlarged the hole in the exhaust pressure nipple and/or where you installed a baffle(s) as well as moving the tank forward. I'm interested to know what finally worked for you, can you let me know?
The newer engines seem to work well - GMS must have identified these problems. The newer engines have the carburettor holes lined up, and they have also modified the mufflers (silver center is older, dull finned is newer).
Just a hint, one time when I was trying baffles, I used a strong spring as the rear spacer (near the exhaust exit) on the bolt. By doing this, when I tightened the long muffler bolt with the nut, it compressed the spring and pushed on the baffle. This took up any slack between the baffles and spacers. It worked well and I thought I should pass this trick along.
Thanks for keeping at it.
Fly4Fun,
Wayne Miller
(in reply to Squid)
       Post #: 64
RE: GMS Engine Tuning Problem - 12/2/2004 2:31:45 PM
Wayne Miller
Status: offline
Hi Andy,
Thanks for your input.
I think with your thoughts it will be interesting to see what your analysis will bring to the table. We need all the input and help we can get!
I think we all agree the GMS engine is a great engine when it works well.
I look forward to the time when you get the engine to "play" with, please keep us informed of what you find and hopefully we can help other modelers.
Thanks for your kind words.
Fly4Fun,
Wayne
