RE: Building a Dynaflite Super Decathlon
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Kit Building >> RE: Building a Dynaflite Super Decathlon
Page: <<   < prev  8 9 [10] 11 12 13 14 15 16 17   next >   >>
Login
RE: Building a Dynaflite Super Decathlon - 6/25/2005 12:50:12 AM
Jim Dines
Status: offline
Gary, the servos are already mounted behind the cabin. I have a G-38 in mine and it balances with no additional weight. Your Saito 1.80 is much lighter and will require some additional nose weight. If you move the servos even further back, you will need to add that much more nose weight to balance. In fact, you might consider installing the servos at a more forward location to avoid or minimize any added weight. There is plenty of room to work with. The kit builds up with a completely open cabin area for the option of detailing it, if you want. Or you can use that space to mount servos. Builder's choice. Good luck with your build. It is a fun kit.
(in reply to Red Baron Gary)
       Post #: 226
RE: Building a Dynaflite Super Decathlon - 6/25/2005 12:53:27 AM
Jim Dines
Status: offline
Marek, best of luck on your maiden.
(in reply to mRqS)
       Post #: 227
RE: Building a Dynaflite Super Decathlon - 6/25/2005 12:19:04 PM
mRqS
Status: offline
Thanks Jim!
here is a very sunny day now (over 30 Celcius degrees), but bit windy.
I'll wait till evening for smaller wind.
In the middle time I'm working again on my Bristol F2b adding a fuselage "lacing".
here is a pic:
Click to see fullsize image.
Click for fullsize
Click for fullsize
_____________________________
Marek
http://rc.marekszulen.net
(in reply to Jim Dines)
       Post #: 228
RE: Building a Dynaflite Super Decathlon - 6/25/2005 2:01:50 PM
Jim Dines
Status: offline
Marek, that is outstanding workmanship on the Bristol.
(in reply to mRqS)
       Post #: 229
RE: Building a Dynaflite Super Decathlon - 6/25/2005 2:23:24 PM
mRqS
Status: offline
It's a kit from Flair Products (UK).
Scale 1:6
Wingspan: 1.98m
Weight: 4kg
Wings area: ab. 150dm2
Wings surface load.....ab. 30g/dm2 (like sailplane)
Powered by Magnum XL .91 FS (four stroke) engine.
more pictures on my site.
and a movie.
< Message edited by mRqS -- 6/25/2005 2:32:32 PM >
Marek
       Post #: 230
RE: Building a Dynaflite Super Decathlon - 7/2/2005 7:15:35 PM
sirjoseph2
Status: offline
I am almost done with my decathlon, However I have a delem with installing the windows. This is the first time I have installed plastic windows and I am hoping someone may have some tips. My kit is has just some plastic windows pre-cut, and acording to the direction I am to just glue them on the outside of the airplane. I would like to creat a mold and have some windows vaccum formed for the perfect fit from the inside. However there is no one in the area I can find that does vacum molding. Any other ideas???
(in reply to mRqS)
       Post #: 231
RE: Building a Dynaflite Super Decathlon - 7/3/2005 1:23:54 AM
Jim Dines
Status: offline
sirjoseph2
What kit are you building? What you describe does not appear to be the Dynaflite kit.
(in reply to sirjoseph2)
       Post #: 232
RE: Building a Dynaflite Super Decathlon - 7/3/2005 2:31:35 PM
sirjoseph2
Status: offline
Good point, I bought just a skeleton at a swap meet. I think it may be a great planes design.
       Post #: 233
RE: Building a Dynaflite Super Decathlon - 7/3/2005 8:32:23 PM
Jim Dines
Status: offline
quote:
ORIGINAL: sirjoseph2
Sorry I can't be much help with your kit, not knowing what it is. On the Dynaflite kit, the front windshield is a formed (molded) clear plastic piece that is trimmed and attached on the outside. I used small screws on mine. The side windows are flat on the full scale as well as the kit. In this case, a single sheet of plastic is glued to the inside of the cabin area for both side windows. This works well on this kit as the cabin sides at this point are 1/8" lite ply and it produces a convincing window effect. Vacuum forming windows would be a lot of unneccessary work in my view. Just cutting the plastic to shape would be a lot simpler, if the one piece idea won't work on your design. Good luck with your kit completion.
       Post #: 234
RE: Building a Dynaflite Super Decathlon - 7/4/2005 6:24:15 PM
mRqS
Status: offline
Few days ago my Decathlon had his maiden flight in www.glidezar.com . On the take off run it's solid like rock. No rudder needed. Just after take off - vertical climbing
It reacts very realistic on the sticks. Landings are gentle like breeze.
During yesterday's landing I broke tail wheel (just under plastic chassis). It's really piece of crap.
I've to make new one.
Will put here some pictures later (when receive it from my friend)
< Message edited by mRqS -- 7/5/2005 10:27:19 AM >
Marek
       Post #: 235
RE: Building a Dynaflite Super Decathlon - 7/4/2005 9:41:41 PM
Jim Dines
Status: offline
Hey, Marek, I'm glad to hear you are pleased with your plane's flight. I recall you have a lot of power to do some glider towing? Do you feel good about the engine power you have?
Good news on your model's maiden flight. I would like to see your tail wheel improvement in case I may need to do something like it in the future (no tail wheel problems on mine, so far, though).
Jim
(in reply to mRqS)
       Post #: 236
RE: Building a Dynaflite Super Decathlon - 7/4/2005 10:03:52 PM
mRqS
Status: offline
Here are few pictures.
Regarding modification - I'll do something like this:
http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXBN39&P=0
I'll do some glider towing next month. Probably will change propeller to 20x8 two-blade or 19x8 tri-blade
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by mRqS -- 7/5/2005 10:26:03 AM >
Marek
       Post #: 237
RE: Building a Dynaflite Super Decathlon - 7/5/2005 2:39:23 AM
Jim Dines
Status: offline
Marek, those are terrific pictures. Some good photographer you have there. The pictures are great, however, i couldn't open the modification you referred to. The plane looks wonderful!
(in reply to mRqS)
       Post #: 238
RE: Building a Dynaflite Super Decathlon - 7/5/2005 10:28:23 AM
mRqS
Status: offline
just corrected link to modification.
Marek
       Post #: 239
RE: Building a Dynaflite Super Decathlon - 7/6/2005 10:30:21 PM
mustangshooter
Status: offline
mRqS, WOW! beautiful photos of what appears to be perfect flying. Great to see it finally in the air, congratulations on your maiden successful flight.
My s. decathlon is almost completed, about 95 %, i am going to add a bisson muffler, batshare, lithium packs, low fuel indicator circuit, i also need to get me a lithium charger, after i get these items i feel i will be ready for the maiden flight.
Mustangshooter
< Message edited by mustangshooter -- 7/6/2005 10:48:22 PM >
(in reply to
