RE: Building a Dynaflite Super Decathlon
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Kit Building >> RE: Building a Dynaflite Super Decathlon
Page: <<   < prev  11 12 [13] 14 15 16 17 18 19 20   next >   >>
Login
RE: Building a Dynaflite Super Decathlon - 1/23/2006 12:24:25 PM
beepee
Status: offline
Lynn,
I cannot speak from personal experience, but the US25 has a reputation of being very under powered for its size and weight. The weight won't be a problem, you will need it on the nose anyway. The lack of power is going to make for disappointing performance.
I would stick with a 35 minimum.
Bedford
(in reply to Lcraig231)
       Post #: 301
RE: Building a Dynaflite Super Decathlon - 1/23/2006 10:50:34 PM
Stickmaster
Status: offline
What He Said!
My Precedent T240 flew with on of these motors, ran very smooth , but under powered. It is a Homelite motor ,runs good but not very strong . See the r/w/b/ plane, the Quadra "same size as G38" on the y plane. I now fly the 240 with a Quadra 35 same weight and about the same size as the Decathlon.
quote:
ORIGINAL: beepee
Lynn,
Bedford
Click to see fullsize image.
Click for fullsize
Click for fullsize
(in reply to beepee)
       Post #: 302
RE: Building a Dynaflite Super Decathlon - 1/25/2006 1:33:45 AM
Richardrc
Status: offline
I'm new to gas engines. What size fuel line do I need for the Zenoah G38?
(in reply to Stickmaster)
       Post #: 303
RE: Building a Dynaflite Super Decathlon - 1/25/2006 1:53:57 AM
Stickmaster
Status: offline
Its not realy the size as the type,most use a 3/32 line, on larger models some jump to a 1/8 tygon gas line Dont forget to convert your tank stopper to a gas one.
This should work fine for a 38cc link to tower http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXD739&P=M
(in reply to Richardrc)
       Post #: 304
RE: Building a Dynaflite Super Decathlon - 1/25/2006 2:37:55 PM
Joe Ortiz
Status: offline
Great thread, I just got my Super Decathlon yesterday, can't beat Towers price with the additional $25 off coupon, this will be my first gasser as well, but I wont be building it for a while since I'll be working on a 1/4 scale Laser 200. I'm intending to install some kind of micro video equipment, also lookin for an engine in the 32 range. Has any body tried a Ryobi coversion engine?
Joe
       Post #: 305
RE: Building a Dynaflite Super Decathlon - 1/25/2006 11:44:41 PM
Richardrc
Status: offline
Is the engine mount, shown on plans, strong enough for the G38? Did anyone make any changes for this engine?
(in reply to Joe Ortiz)
       Post #: 306
RE: Building a Dynaflite Super Decathlon - 1/26/2006 4:30:07 AM
Jim Dines
Status: offline
The plan design is good. On mine, I cut new firewall and engine mount parts from 1/4" aircraft ply instead of laminating the 1/8" lite ply pieces. Just my personal preference. The kit wood will probably work just fine.
       Post #: 307
RE: Building a Dynaflite Super Decathlon - 1/31/2006 10:58:34 PM
Rob C
Status: offline
Hi all. I just have purchased my Dynaflight Decathlon today. I made the decision from this thread, and will incorporate some of the ideas of this thread. I plan on using a G26 that I already have and by the looks of it I will have to move my servo's forward. I'm just in the process of completing a TF GS P47.
(in reply to Jim Dines)
       Post #: 308
RE: Building a Dynaflite Super Decathlon - 1/31/2006 11:02:01 PM
Joe Ortiz
Status: offline
I'm not sure which engine to go with on this plane, I wonder if a Fuji 32 will have enough athority to pull it at 5800ft plus altitude.
Joe
(in reply to Rob C)
       Post #: 309
RE: Building a Dynaflite Super Decathlon - 1/31/2006 11:26:45 PM
wiltonh
Status: offline
Hi,
Just order a SD kit from tower. Looking forward to getting started. Planning on a G38 with B&B starter and smoke setup.
Thanks for all the posts and info here. Has helped with the choices and am sure will be calling on specific help before its over.
Will
       Post #: 310
RE: Building a Dynaflite Super Decathlon - 2/4/2006 4:07:54 PM
Joe Ortiz
Status: offline
I just got a G-38, where do you get the B&B starter?
Joe
(in reply to wiltonh)
       Post #: 311
RE: Building a Dynaflite Super Decathlon - 2/4/2006 5:19:26 PM
RCKen
Status: online
I'm just now putting together my list of what I need to buy to build this plane. I'm planning on getting the Zenoah G-38 for this, but I Have a question abut the muffler. I was looking at the Bisson Pitts muffler for this plane, but the one I found I'm not sure about it fitting properly in the cowl. Here is the Bisson muffler I found on Horizon Hobby: http://www.horizonhobby.com/Shop/ByCategory/Product/Default.aspx?ProdID=BIS07138 Is this the proper muffler to fit in the cowl of this plane??
Thanks in advance.
Ken
_____________________________
The take off is optional, but the landing is MANDATORY!!
AMA # 712539 www.gettingairborne.com
Moderator- Beginner''s, Sport Flying, Off-Topic, & AMA Discussions
RCU Community Moderator
       Post #: 312
RE: Building a Dynaflite Super Decathlon - 2/4/2006 10:51:46 PM
Joe Ortiz
Status: offline
That's the right one, I'm getting one myself, the stock muffler won't work in a cowled application.
Joe
(in reply to RCKen)
       Post #: 313
RE: Building a Dynaflite Super Decathlon - 2/5/2006 3:44:27 AM
Jim Dines
Status: offline
Or you can get the B&B twin stack for around $35. It's what I use.
(in reply to RCKen)
       Post #: 314
RE: Building a Dynaflite Super Decathlon - 2/5/2006 5:26:11 AM
wiltonh
Status: offline
Joe,
Go to bennettbuilt.com
They sell the zenoah already rigged up for smoke and or spring starter with a mount
Looks like a great resource.
Will
       Post #: 315
RE: Building a Dynaflite Super Decathlon - 2/5/2006 4:16:02 PM
