RE: Building a Dynaflite Super Decathlon
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Kit Building >> RE: Building a Dynaflite Super Decathlon Page: <<   < prev  2 3 [4] 5 6 7 8 9 10 11   next >   >>
Login
RE: Building a Dynaflite Super Decathlon - 12/8/2004 9:45:00 PM
mRqS
Status: offline
haha... thanks 2 U 2 "Cruz"
I'm glad to see, that I'm not an alone Decathlon builder now
_____________________________
Marek
http://rc.marekszulen.net
(in reply to cruzmissile)
       Post #: 76
RE: Building a Dynaflite Super Decathlon - 12/9/2004 12:29:54 AM
Chevalier
Status: offline
Here's my Decathalon currently under construction. Note the laminated wingtips in the first picture. I will be using an OS 1.20 for power.
Click to see fullsize image.
Click for fullsize
Click for fullsize
I can rebuild it. I have the technology
       Post #: 77
RE: Building a Dynaflite Super Decathlon - 12/9/2004 1:38:26 AM
cruzmissile
Status: offline
Chevalier,
Looks nice, I like your table, it makes the SD look like a .40
Have you ever thought about building over the mid section of the landing gear so that the belly would be smooth and continuous?
What goes up must come down, and that is the Landing Gear!
(in reply to Chevalier)
       Post #: 78
RE: Building a Dynaflite Super Decathlon - 12/10/2004 2:41:07 AM
cruzmissile
Status: offline
I did some work on the wing strut mounts. I didn't feel like having to "find" block that would fit, so I laminated four 1/8" light ply together to get the desired size and shape. I've found that laminating wood can be pretty easy to get the shape and size you want and need.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 79
RE: Building a Dynaflite Super Decathlon - 12/10/2004 12:52:00 PM
beepee
Status: offline
Cruz,
I did that with mine (built the belly smooth, without the gear opening). I used the light ply formers from that area and built a small insert from the strut support to forward of the gear, about twice the length of the design opening. I needed to get to the strut support as I made that of aluminum flat bar running across the belly and screwed to the gear mounting plate. I used the lighting holes in the formers to create guide pins (holes on stationary piece, the dot removed from the hole glued on the insert to hold position), then I drilled and tapped the landing gear at the center for a 10-32 screw. Used a nylon screw through the insert.
Looks alot better.
Bedford
       Post #: 80
RE: Building a Dynaflite Super Decathlon - 12/10/2004 8:26:07 PM
cruzmissile
Status: offline
I was doing some research on prices for various engines. Originally I was going to go with the G-38 $299, but I also found a US-41 for about $260. The US engines is less expensive than the G-38, my question is how the US matches with the Zenoah G-38.
Are they equal in weight?
Is one more reliable than the other one?
Does one tend to start easier than the other?
Just need some input before making my final decision. Thanks.
(in reply to beepee)
       Post #: 81
RE: Building a Dynaflite Super Decathlon - 12/10/2004 8:36:16 PM
mRqS
Status: offline
Cruz,
As I heard, ZG is more reliable than US or Fuji, but all of them are heavy and not so powerful.
I'd propose a DA or ZDZ engine (www.rcshowcase.com). They're lighter and much more powerful.
Marek
       Post #: 82
RE: Building a Dynaflite Super Decathlon - 12/11/2004 4:40:33 AM
cruzmissile
Status: offline
I went shopping today and found some stuff to do some interior work. It's not the best scale interior, but it's my first attempt at it. I found some felt sheets that I'm going to use for carpeting the interior, I got some blocks of foam for making seats and I got some leather sheets to cover the seats. I also found some .008" aluminum sheets to make door trim.
Click for fullsize
Click for fullsize
(in reply to mRqS)
       Post #: 83
RE: Building a Dynaflite Super Decathlon - 12/11/2004 4:43:14 AM
cruzmissile
Status: offline
Marek,
I'll check out the website and see how the DA compares, if it comes out being too expensive, I'll ultimately settle with the G-38.
(in reply to mRqS)
       Post #: 84
RE: Building a Dynaflite Super Decathlon - 12/11/2004 8:01:47 AM
mRqS
Status: offline
quote:
ORIGINAL: cruzmissile
Don't forget a door's "glassing" before felt glueing
They're more expansive for sure.
DA's are here: http://www.desertaircraft.com/
Marek
       Post #: 85
RE: Building a Dynaflite Super Decathlon - 12/11/2004 2:15:42 PM
Jim Dines
Status: offline
cruz,
Mine is framed up with the G38, servos and battery mounted. Balance appears right on at this point. I have heard that this kit builds tail heavy, and up front weight will be required. May as well have the weight in the engine.
       Post #: 86
RE: Building a Dynaflite Super Decathlon - 12/11/2004 4:40:39 PM
cruzmissile
Status: offline
I guess I'll stick with my original plan and get a G-38.
Hey Marek,
What do you mean by this? Is there something I forgot?
(in reply to Jim Dines)
       Post #: 87
RE: Building a Dynaflite Super Decathlon - 12/11/2004 5:53:22 PM
apalsson
Status: offline
cruz,
The G38 is an excellent engine. It may be a bit on the heavy side but it's one of the most reliable engines on the market.
I guess mRqs was reminding you to fit the glass in the window and then felt and trim the interior
Ari
       Post #: 88
RE: Building a Dynaflite Super Decathlon - 12/11/2004 9:50:53 PM
