RE: Building a Dynaflite Super Decathlon    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Kit Building >> RE: Building a Dynaflite Super Decathlon
Page: <<   < prev  65 66 67 68 69 70 71 [72] 73 74   next >   >>
Login
RE: Building a Dynaflite Super Decathlon - 12/18/2012 4:08 PM
BOLT
Score: 100
Last Login: 4/17/2013
Status: offline
Great forum!!!!!!
I've been building my SD since Febreuary of this year. I'm almost finish but need help in two items.
1. I read that the landing gear is weak. I have seen some pictures that show some sort of wire+wheel collars used for reinforcement but the details on how is done is
absent. Can some tell me exactly how it's done? (some pictures would be great).
2. I'm using a G-38 in mine which means that I have to remove practically all of the bottom cowl. Is the Fibreglass specialties a better option? I mean, do I have to do the
same amount of removal of material? I think I read somewhere that this cowl is a better fit for this engine.
Your response is very appreciated.
Bolt
_____________________________
Blessed is the man who has a hobby for he has two worlds in which to live.
Hide Signatures
(in reply to nh4clo4)
       Post #: 1776
RE: Building a Dynaflite Super Decathlon - 12/18/2012 5:13 PM
nh4clo4
Score: 105
Last Login: 5/19/2013
Status: offline
I have aG38 in mine with the stock cowl, It wasn't too bad, I can get more pictures if you want.
as far as the landing gear, You bend a 5/32" music wire to the shape of the landing gear, then use wheel collars and 6/32 screws, that go through the aluminum, into the wheel collar, and tighten on the music wire, it takes some filing to get the screws the right length, where they tighten to the music wire and the aluminum at the same time.
ED
Click to see fullsize image.
Click for fullsize
Goldberg Tiger Club #25
Hide Signatures
(in reply to BOLT)
       Post #: 1777
RE: Building a Dynaflite Super Decathlon - 12/18/2012 5:32 PM
WILDCRASHWILLY
Score: 120
Status: offline
Bolt,
Glad your coming along on you Decath. Look at post number 1433 and 1434 on I think it was page 58. I took a few pictures of what I did. Hope that helps.
On another note, I did some calculations and it looks like I need 9 oz of lead up front to balance. I don't have any so I going to run to a tire store this afternoon and get some lead strips that they use to balance mag wheels.
Bill
Hide Signatures
(in reply to BOLT)
       Post #: 1778
RE: Building a Dynaflite Super Decathlon - 12/18/2012 5:55 PM
BOLT
Score: 100
Status: offline
Thanks a lot you guys!
I plan to incluse some pictures of mine soon.
Hide Signatures
       Post #: 1779
RE: Building a Dynaflite Super Decathlon - 12/18/2012 6:07 PM
dabrown
Score: 100
Status: offline
Bolt,
I'm in the process of replacing my Saito 180 with a G-38. As you did, I cut out most of the bottom to clear the spark plug, wire and cylinder head. Some was already missing from the Saito install so I could possibly fill back in a part behind the lower scoop. On the side I had to cut out about a 1 inch by 1 1/2 inch hole to clear the carb.
I don't think any cowl could enclose it all. The Fiberglass Specialties version looks like it might be a bit wider (?) so it may enclose the carb.
Overall I'm not worried about the open bottom and the carb is accessible too. (My G-38 is the B&B Specialties/Bennett version so yours could possibly have a different carb mount). I was actually amazed that the flywheel and magneto parts fit inside as well as they do.
Dave
Fleet Brotherhood #10
Hide Signatures
(in reply to BOLT)
       Post #: 1780
RE: Building a Dynaflite Super Decathlon - 12/18/2012 6:13 PM
Zor
Score: 181
Status: offline
quote:
ORIGINAL: dand@oz.net
Mine was tail heavy, and I added about 8 oz to the nose to balance it out. If I had the chance, I would move the elevator and rudder servos forward to the cabin instead of their default location. Also, I'd hollow out those terribly heavy wing tips - something I knew better about when I put them on but blew off out of ignorant disregard. The plane isn't too unstable when tail heavy (I flew mine tail heavy many flights before adding the 8 oz), but it flys much better when balanced.
Hello dand,
Those "terribly heavy" wing tips have a very short "moment arm".
Hollowing them would reduce overall weight but would have a small effect on the CG location.
Zor
Hide Signatures
(in reply to dand@oz.net)
       Post #: 1781
RE: Building a Dynaflite Super Decathlon - 12/18/2012 6:32 PM
Zor
Score: 181
Status: offline
quote:
ORIGINAL: WILDCRASHWILLY
Well guys,
I have an issue. The CG is supposed to be 3 3/8 from leading edge give or take a 1/2 inch. Mine comes in at 4 inches an 1/8 inch past the Max allowable. I thought with the gas engine this would not be an issue.
Has anyone flown this plane with the CG this far back. Don't really have anything left to move forward. Don't want to but I'll add two or three once's of lead to the nose if I have to. I normally end up setting my planes a little tale heavy but, not on the maiden flight.
I'll read some of the earlier posts to see if anyone else published their cg but I don't remember anyone being past 3 1/2.
Hi WILDCRASHWILLY,
The CG range is not always available from designers or manufacturers.
In your case you are quoting it as being 1/2" from 3 3/8" so the range is from 2 7/8" to 3 7/8" and you found your CG at 4".
If you know how these limits are established and what to expect as the CG approaches the limit either forward or rear limit then you will I imagine do the necessary correction.
If needed I can explain how the limits are established.
Zor
Hide Signatures
(in reply to WILDCRASHWILLY)
       Post #: 1782
RE: Building a Dynaflite Super Decathlon - 12/18/2012 7:08 PM
BOLT
Score: 100
Status: offline
Dave:
My G-38 is using the same muffler as yours. I changed the magneto to an electronic ignition, it gives me better idle and reduce a little bit of weight from the nose. I'll be using the stock cowl but plan to get the fiberglass one ( plus wheel pants) this Xmas. Let's see what happens now.
Bolt
Hide Signatures
(in reply to dabrown)
       Post #: 1783
RE: Building a Dynaflite Super Decathlon - 12/18/2012 7:25 PM
dand@oz.net
Score: 100
Last Login: 5/6/2013
Status: offline
Thanks for the clarification Zor, yes hollowing out the wing tips is intended to reduce the overall weight, knowing it will not affect the CG much. If I could hollow them out and remove the 8 oz in the nose by moving the servos forward, I could remove almost a pound of the overall weight. My plane as it is now has too high of a stall speed and removing weight would improve it.
Hide Signatures
(in reply to BOLT)
       Post #: 1784
RE: Building a Dynaflite Super Decathlon - 12/19/2012 5:13 AM
flyathome
Score: 100
Last Login: 5/18/2013
Status: offline
This is my Dynaflite Super Decathlon I just finished last month. It is powered by a DLA 32 and guided by an Airtronics
SD 10G. I am very pleased with the way it flies. The kit was very easy to build with no real problems encountered.
Steve
Click for fullsize
Click for fullsize
Click for fullsize
I don''''t crash. The planet keeps getting in my way!!!!
Hide Signatures
       Post #: 1785
RE: Building a Dynaflite Super Decathlon - 12/19/2012 8:30 AM
Kolbboer
Score: 100
Last Login: 4/27/2013
Status: offline
Hi,
I have a G38 in mine, and i did not remove any material of the bottom of cowl at all.
(see pictures of original cowl)
Maiden flight:
http://www.youtube.com/watch?v=QvqYuCDdWhg
RGS
Jan
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to BOLT)
       Post #: 1786
RE: Building a Dynaflite Super Decathlon - 12/20/2012 4:52 PM
WILDCRASHWILLY
Score: 120
Status: offline
Wow,
30 to 40 MPH winds here today . Very unusual for this area. Needless to say, I'm not brave enough to maiden in this. Hope everyone is doing well. Lets see some pictures red_jeepster and Drube.
Bill
Hide Signatures
(in reply to Kolbboer)
       Post #: 1787
RE: Building a Dynaflite Super Decathlon - 12/20/2012 7:46 PM
Red_Jeepster
Score: 105
Status: offline
Just finishing a project for Christmas. As soon as the shop is cleaned up, I will lay out the SD! No one has any info about going electric on this build, eh?
Some Preachers play Golf, I would rather FLY RC!
Ultra Sport Brotherhood #74
Hide Signatures
       Post #: 1788
RE: Building a Dynaflite Super Decathlon - 12/20/2012 9:27 PM
WILDCRASHWILLY
Score: 120
Status: offline
The only thing I've seen is Glow and Gas. Might check over on the F****gG***ts site and see if any of those guys have tried electric. BTW: saw the weather on the TV a few minutes ago, getting 49 mph wind gust today at the airport in Paducah KY which is about 18 or 20 miles from my location. about 5 miles from our club field.
Bill
Hide Signatures
(in reply to Red_Jeepster)
       Post #: 1789
RE: Building a Dynaflite Super Decathlon - 12/20/2012 10:05 PM
Red_Jeepster
Score: 105
Status: offline
Getting set for the big winter storm here in PA. I will just stay with my plan for 35cc gas and smoke. Love the sound. Electric... What was I thinking! !!
Hide Signatures
       Post #: 1790
RE: Building a Dynaflite Super Decathlon - 12/24/2012 1:20 AM
dabrown
Score: 100
Status: offline
As I mentioned earlier, I've been retrofitting my SD with a G-38. See pics. Hole in top of cowl deck is to access mounting bolts. Fortunately it's covered by the cowling. Now I need to install the tank and plumbing. Been thinking about going with a two battery/two receiver set up. Would appreciate any comments on doing so. My purpose in doing so is to increase reliability through redundancy.
dave
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 1791
RE: Building a Dynaflite Super Decathlon - 12/25/2012 3:20 AM
Red_Jeepster
Score: 105
Status: offline
Dabrown, For what it's worth... I have been building and flying for over 30 years and never had seen really good reason for redundant rcvr set-up. Especially now (today) with the quality of receivers being provided by the big mfrs. I've never lost a plane due to receiver failure, only my mistakes and once a servo wire got rubbed thru and shorted, causing a pretty impressive crash. BUT, you are the builder of your own plane, and need to answer that for yourself.
My bench is now clear! I am starting the layout for my SD wings day after tomorrow! WHOOO HOOOO! My wife grabbed up all my bits on my Tower Wish List, and now they are in my hands - everything for the SD build.
Photos will come.
I won't consider monokote because of the plane. (not to mention I have become really disappointed in it over the last few years)
So I am planning on Coverite. Maybe Poly Lite from Stits.
Hide Signatures
       Post #: 1792
RE: Building a Dynaflite Super Decathlon - 12/27/2012 12:19 AM
Red_Jeepster
Score: 105
Status: offline
Tail feathers are started! No need to post pics, as nothing out of the ordinary was done so far.
Hide Signatures
       Post #: 1793
RE: Building a Dynaflite Super Decathlon - 12/27/2012 1:15 AM
nh4clo4
Score: 105
Status: offline
Keep at it, and keep us informed.
Does anybody know if the Seagull 120 Size Decathalon wheel pants will work on this? They are only 16.00 and are fiberglass, it would be easy to paint.
Hide Signatures
       Post #: 1794
RE: Building a Dynaflite Super Decathlon - 12/28/2012 6:06 PM
WILDCRASHWILLY
Score: 120
Status: offline
Hey guys,
With the exception of balancing, which I have'nt been in a big hurry about, due to the weather holding up any flying, I'm finished with my Decath. I am starting a new plans build thread for the Hot Hots, (link is attached) but, I will be monitoring this thread and commenting from time to time with you guys as I have really enjoyed the build once I got into it. In addition, I have enjoyed the friendships we have formed on this thread.
http://www.rcuniverse.com/forum/m_11347209/tm.htm
Bill
Hide Signatures
       Post #: 1795
RE: Building a Dynaflite Super Decathlon - 12/30/2012 12:42 AM
WILDCRASHWILLY
Score: 120
Status: offline
Hey Drube and Bolt,
Any luck with your Decath builds? Haven't heard from you guys lately.
Bill
Hide Signatures
       Post #: 1796
RE: Building a Dynaflite Super Decathlon - 12/30/2012 9:38 PM
Red_Jeepster
Score: 105
Status: offline
I've gotten my tail feathers built, sanded to shape and Robart hinge pockets installed. I will be installing flying wires on the tail, so I included the dowel plug in the vert stab.
This next week should see more progress. I just placed an order for more of the bits & pieces I need for this build. Metal gear servos for certain.
Hide Signatures
       Post #: 1797
RE: Building a Dynaflite Super Decathlon - 1/5/2013 11:21 PM
Red_Jeepster
Score: 105
Status: offline
All finished with Tail feathers. Now I'm clearing off the bench for the start of the wing panels. This is going to take a bit of extra time, as I am NOT building the 2-piece as per the instructions. Instead, I am building the panels with flat wing root to butt-up against the fuse. The Fuse is to be modified to include the shape of the wing. This solves 2 problems. 1. A Good SOLID mounting of the wing as the wingtube will pass thru the fuse, and not just 2 screws holding it on. 2. it gives me a way to access the interior of the fuse while the wings are mounted. I can load the cargo bay with all those ping-pong balls or skydivers or candy from the top. An access hatch allows this all.
Hide Signatures
       Post #: 1798
RE: Building a Dynaflite Super Decathlon - 1/6/2013 2:44 AM
WILDCRASHWILLY
Score: 120
Status: offline
Sounds great Red,
Be sure and take pictures. I like to see how mods are done.
Bill
Hide Signatures
       Post #: 1799
RE: Building a Dynaflite Super Decathlon - 1/6/2013 3:06 PM
dabrown
Score: 100
Status: offline
Test flew my SD with the G-38 yesterday. Second flight ended as a dead stick. The Tygon fuel line melted against the muffler! I didn't expect that to happen, consequently I didn't take care to route the lines properly.
It was nose heavy and my first takeoff attempt ended up with the prop digging into the runway. Got it airborne and it flew OK, but definitely not great. The CG needs to move back alot so I'll be moving the battery and adding ballast to the tail. The other thing is it needs more prop. The G38 with an 18-8 revs up, but the airplane doesn't accelerate. Needs a 20 inch prop and that will create ground clearance problems...old story with this airplane and the big gassers. I ordered an 18-10 so may give that a try.
Dave
Hide Signatures
       Post #: 1800
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.703RCU1
