dornier
KY, USA Status: offline
Hi, The battery is a Kokam is a "3 Cell 11.1V 1500mAh High Discharge Lithium Polymer Battery Pack". SPECS: Applications: Speed 400, parallel for Speed 600 electric aircraft Rating: 8C/82% Output: 11.1V nominal, 1500mAh Is this the right one? Thanks again, George quote:
ORIGINAL: Erich_F HI, 1) Will be using a JR XP783 H Radio which has helicopter settings. The radio was sent to JR about 2 years ago and they enabled CCPM. I now have a selection for SWASH and it allows for NORM, 2,3, or 4 servos. Which one do I select for the TREX 450X? Is the TREX a 120 or 180 CCPM helicopter? Honestly, I don't know what version of CCPM I have in this radio since it was an undocumented feature. The Trex is a traditional mix collective system, just like on the Raptor series. You would use the NORM mode. 2) I'm about to buy a Kokam 3 cell 1500maH battery, will this be okay with the Align motor and Align 25A BEC? Make sure it's the high discharge Kokam. I prefer the ThunderPower Gen 2 2100mA 3S and 1320mA 3S packs. 3) Should I buy a heatsink for both the battery and motor? Not required, the Trex has a fan integrated with the tail drive gear. Just adds weight. 4) Which pinion should I use? 8T, 9T, 10T, 11T, etc? The Align Outrunner type 400S motors use the 13T pinion, one of the four supplied in the kit. 5) Will a futaba GY401 work with a JR receiver (226X six channel reciever)? Yes, it will work with any radio. You use ch5 (gear channel) to set the gain via EPA setting. Have fun, and welcome to the club. If you want some detailed pics, PM me your email and I will send some to you. Erich
