RCXPLANES
OR, USA Status: offline
quote:
ORIGINAL: skyhawknut Where did you get the 9 tooth? and how hot does your motor get? I got the 9, 10 and 11 tooth from Heli Hobby but couldn't find them on line so I called. Thats when I was talked out of the 8 T. I have only flown it once for about 7-8 min outside with a very poorly working gyro before I got some good info on it's setup so there was lots of landing and zero pitch running then. I also got one of Heli Hobby's 20 mm motor heat sinks (the blue $7.99 one) at the same time and have never run it without it on. Other than that I have only hovered for 5 - 10 seconds at a time and landed to adjust the gyro gain. I didn't use my infrared temp gun but had no trouble touching the bottom of the motor as long as I wanted. It was warm but not hot at all. The battery was also warm but not hot. My trrottle curve in flight mode 1 was set at 70% as well so I wasn't at full power either. While I was trying to set up the gyro at 10:30 pm in my garage. I got the RATE MODE set fine and was playing with the gain on the HH Mode when she drifted a bit. I just touched my large toolbox with a rotor blade. I thought I had it. Things went bad from there. I just got the parts this evening (feathering shaft, boom, horizontal fin mount) and put everything right. I decided to wait till tomorrow to finish the gyro setup, outside this time. I am just not good enough yet to hover in the garage with the gyro just out and have great control. This is my first helicopter. I will have to let you know how warm everything gets with my infrared temp gun after tomorrows activities. Bud
< Message edited by errolw98 -- 12/3/2004 9:09:05 AM >
_____________________________
Life is short. Fly hard and enjoy. Bud Wilkinson, RC-Xplanes, www.rcxplanes.com
