CG330 question for mike
Tower Hobbies
Logged in as Guest
  Printable Version
JR R2000, JRPR2000 10CH RX, and JR Synth TX Module
Seller:  Erick Royer
Details:   $400.00   |  9/1/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Radio Manufacturer Direct Support >> Hitec/MultiPlex Radios- Ask Hitec Customer Service >> CG330 question for mike
Page: [1]
Login
CG330 question for mike - 8/13/2002 9:21:52 PM
rajul
Status: offline
Dear Mike, I was using my cg330 field charger to charge my dead flat glow igniter (1300mah battery). It was charging for two hours when I decided to stop it bacause the led did not blink at all. I was expecting to be fully charged around an hour. I was also concerned that the 60-min time limiter did not stop the charging. Is there anything wrong with my unit ? I checked the battery voltage and it was at 1.4V just after charging.
Thanks.......................
PS Sorry that I had to post this here although I know that this is a slightly different forum. I thought it will be easier to contact you here.
       Post #: 1
CG330 question for mike - 8/14/2002 3:56:10 AM
MikeMayberry
Status: offline
The glow charger does not have a 60 minute cut off, it just charges at 1amp and then shuts off when the battery peaks.
Mike.
(in reply to rajul)
       Post #: 2
CG330 question for mike - 8/14/2002 4:10:47 AM
rajul
Status: offline
Hi Mike, how does the charger indicate that it has peaked ? Is two hour charge time normal ? Thx.............
(in reply to rajul)
       Post #: 3
CG330 question for mike - 8/14/2002 8:38:28 PM
MikeMayberry
Status: offline
The light will go from solid to blinking. 2 hours is 2000mah.
Mike.
(in reply to rajul)
       Post #: 4
CG330 question for mike - 8/14/2002 9:47:12 PM
rajul
Status: offline
Hi Mike, is it possible that the charging current is below 1A if my 12V battery is weak ? Does the cg-330 automatically regulates the currrent level to 1A irregardless of the 12V battery level ? BTW, the weak battery LED in my charger did not light up during the 2-hour charging period.
Thanks again for your asistance .............
(in reply to rajul)
       Post #: 5
CG330 question for mike - 8/15/2002 9:55:40 PM
MikeMayberry
Status: offline
The battery can be as low as 10V and it would still charge at 1A.
Mike.
(in reply to rajul)
       Post #: 6
CG330 question for mike - 8/16/2002 5:22:02 AM
rajul
Status: offline
Dear Mike, I suppose this means that my charger is faulty. It is only two months since I purchased it and rarely used. How can I send it in for warranty replacement ? Thx............
(in reply to rajul)
       Post #: 7
CG330 question for mike - 8/19/2002 9:48:55 PM
MikeMayberry
Status: offline
http://www.hitecrcd.com/Support/service_and_repair.htm
(in reply to rajul)
       Post #: 8
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.609RCU1
