tigercat
Joined: 1/12/2002 From: Georgetown, KY, USA Status: offline
Lee, good choice in a warbird. I have two of the Yellow Spits and am using 3-W 60i's for power. They are about the right weight and size for the application. These engines have the rear carb and make for a clean installation. Only a very little of the head fins will protrude from the bottom of the cowl. Cooling does not seem to be a concern, but the Johnson muffler needs a lot of refabrication to be used, maybe a different muffler company makes an easier to modify muffler for this plane?? These engines provide LOTS of power for this plane, some say this is too much engine for this application but my answer to this statement is, the plane needs the weight in the front anyway so why not utilize an engine with more power than an engine with lesser power along with pounds of usless lead. The extra power may be needed at some point in the models life. I do not fly glow fuel any longer due to costs of fuel, plugs, etc, also the reliability of the gassers is a factor. Good luck and happy flying to you. Les
