RE: 1/2A trainer anyone?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> "1/2 A" & "1/8 A" airplanes >> RE: 1/2A trainer anyone? Page: <<   < prev  1 [2] 3 4 5 6 7 8 9 10   next >   >>
Login
RE: 1/2A trainer anyone? - 11/2/2004 7:13 AM
Andrew
Score: 105
Last Login: 6/19/2013
Status: offline
The "LST" is a nice choice -- Lynn was partial to the high wing Simple Series -- I think he would like it. He flew the 1/2A SST, so why not the 1/2A LST.
_____________________________
the "other" andrew
I'm not older than dirt, but I can remember when it was patent pending
Hide Signatures
(in reply to mclintock)
       Post #: 26
RE: 1/2A trainer anyone? - 11/2/2004 7:44 AM
Bipe Flyer
Score: 105
Last Login: 12/3/2012
Status: offline
LST seems like a natural.
I was thinking of these too:
LS Trainer
LS 40 (40" span)
LS 101 (101cm span)
LS .049
LS Special
1/2A all the way!
Club Saito #151
Hide Signatures
(in reply to Andrew)
       Post #: 27
RE: 1/2A trainer anyone? - 11/3/2004 3:58 AM
jboy381-RCU
Score: 100
Last Login: 2/22/2008
Status: offline
quote:
ORIGINAL: Bipe Flyer
LS Trainer
LS Special
i like LS trainer but LS special seems more like a dedication to me...after all it will be in Lynn's memory...
what you guys think???
john
count your blessings,not your problems
Hide Signatures
(in reply to Bipe Flyer)
       Post #: 28
RE: 1/2A trainer anyone? - 11/22/2004 8:53 PM
cortacesped
Score: 100
Status: offline
Any updates ?. Regards.
Claudio
Hide Signatures
(in reply to jboy381-RCU)
       Post #: 29
RE: 1/2A trainer anyone? - 11/22/2004 9:11 PM
astro-hog
Score: 100
Last Login: 12/25/2004
Status: offline
Where can I get those plans from! I'm game baby!
U.S.A. LOVE IT OR LEAVE IT!
Hide Signatures
(in reply to cortacesped)
       Post #: 30
RE: 1/2A trainer anyone? - 11/22/2004 9:24 PM
cwrr5
Score: 100
Last Login: 4/26/2013
Status: offline
Me too! me too!
BTW - Bipe, I saw in other posts that you developed a "tile print" program. How can I get a copy?
< Message edited by cwrr5 -- 11/22/2004 9:25 PM >
Hide Signatures
(in reply to astro-hog)
       Post #: 31
RE: 1/2A trainer anyone? - 11/22/2004 10:59 PM
DustOffUH1
Score: 100
Status: offline
You can find more info on Tile Printing and the program on the following site. Also some GREAT free plans to. For the tile print info scroll towards the bottom. Hope this helps!
http://my.pclink.com/~dfritzke/
Joe
Lots o Planes & Helicopters. 5 more planes & 1 heli to build ;)
Hide Signatures
(in reply to cwrr5)
       Post #: 32
RE: 1/2A trainer anyone? - 11/23/2004 9:45 PM
cwrr5
Score: 100
Status: offline
Thanks! Nice site!
< Message edited by cwrr5 -- 11/23/2004 9:46 PM >
Hide Signatures
(in reply to DustOffUH1)
       Post #: 33
RE: 1/2A trainer anyone? - 11/23/2004 11:34 PM
DustOffUH1
Score: 100
Status: offline
No problem. Yep, he's got lots of nice old time plans posted. Gonna have to build some, one of these days. Some are tiled too, and the best part, they are free. Very nice of him to do that
Hide Signatures
(in reply to cwrr5)
       Post #: 34
RE: 1/2A trainer anyone? - 11/24/2004 12:11 AM
cwrr5
Score: 100
Status: offline
Free is ALWAYS good!
Hide Signatures
       Post #: 35
RE: 1/2A trainer anyone? - 1/2/2005 9:30 PM
adr_ian64
Score: 100
Last Login: 11/12/2008
Status: offline
hows those trainer plans going?
Hide Signatures
(in reply to cwrr5)
       Post #: 36
RE: 1/2A trainer anyone? - 1/3/2005 9:57 AM
Bipe Flyer
Score: 105
Status: offline
The plan is done.
RCU resized the plan when I uploaded it, but you can get a high res version from the "1/2A all the way!" group under "Documents" > "Plans".
The 1/2A All the Way MSN site is gone, so here are new links to the plans.
http://donatelli.net/LST.zip
http://donatelli.net/LST-Laser-parts.zip
If you have Tile Print, you can use it to print the GIF, otherwise you can use the PDF version.
When printing the PDF version, make sure that "Page Scaling" is set to "none" and "Choose Paper Source by PDF page size" is unchecked.
If anyone builds it, please post pictures.
EDITED to include the current plans links- bcm
Click to see fullsize image.
Click for fullsize
< Message edited by BMatthews -- 12/20/2009 12:27 AM >
1/2A all the way!
Club Saito #151
Hide Signatures
(in reply to adr_ian64)
       Post #: 37
RE: 1/2A trainer anyone? - 1/3/2005 8:57 PM
adr_ian64
Score: 100
Status: offline
Great job. I'll post some pictures when I'm done
Hide Signatures
       Post #: 38
RE: 1/2A trainer anyone? - 1/4/2005 3:17 AM
adr_ian64
Score: 100
Status: offline
What type of wood do you use for the sides of the fuse.? Theres some Balsa 1/8" sheet, and theres 'Lite ply' 1/8" plywood. The plywood sure is expensive though. 12 bucks(Canadian) for a 12"x 48" piece. maybe I'll stick with balsa if theres no strenght issues with using it.
Oh...and what type of glue do you use(havent built a plane before)? I have some medium CA glue. do I need any epoxy or will it hold with just the CA?
< Message edited by adr_ian64 -- 1/4/2005 3:20 AM >
Hide Signatures
       Post #: 39
RE: 1/2A trainer anyone? - 1/4/2005 3:40 AM
Bipe Flyer
Score: 105
Status: offline
The plans show 3/32" balsa. Only use plywood for the firewall and balsa everywhere else. Also add a couple of pieces of tri-stock behid th firewall Only use CA, you shouldn't need any epoxy for this plane except maybe the firewall. If you build it with ailerons, put .75" dihedral on each wing tip. If you build it without ailerons, use 1.75" diheadral on each tip.
1/2A all the way!
Club Saito #151
Hide Signatures
       Post #: 40
RE: 1/2A trainer anyone? - 1/4/2005 4:17 AM
adr_ian64
Score: 100
Status: offline
I put in a order for the wood just now going to go pick it up tomorrow.
This project Is going to be fun to build
Happy flying/building
Hide Signatures
       Post #: 41
RE: 1/2A trainer anyone? - 1/4/2005 9:04 AM
keepiru1
Score: 100
Last Login: 5/18/2006
Status: offline
Bipe Flyer,
What did you name it there on 1/2 A all the way? The LST? I do agree that he'd be all over it. Here's to you, Archie.
< Message edited by keepiru1 -- 1/4/2005 9:31 AM >
Revver Bro 114 'I have prayed to God for one thing in my life:to have people laugh at my enemies and they have'-Voltaire
Hide Signatures
       Post #: 42
RE: 1/2A trainer anyone? - 1/4/2005 9:16 AM
Bipe Flyer
Score: 105
Status: offline
Yes, it is named "LST 1/2A Trainer".
1/2A all the way!
Club Saito #151
Hide Signatures
(in reply to keepiru1)
       Post #: 43
RE: 1/2A trainer anyone? - 1/4/2005 9:35 AM
keepiru1
Score: 100
Status: offline
Okay now Bipe Flier.....I'll need some 1/2A floats or skis to go on this thing! *LOL* How long for those accessories to come out? *EG*
Hide Signatures
       Post #: 44
RE: 1/2A trainer anyone? - 1/4/2005 9:43 AM
Bipe Flyer
Score: 105
Status: offline
I just so happens that I made a DAT file for cutting floats on my foam cutter.
Click for fullsize
1/2A all the way!
Club Saito #151
Hide Signatures
       Post #: 45
RE: 1/2A trainer anyone? - 1/5/2005 5:59 AM
goldy9955
Score: 100
Last Login: 12/1/2012
Status: offline
Hi Bipe, I've never scratch built anything or from plans only. You make me want to try it. I'm not too computer savvy and don't know what programs or other stuff I need to get plans from sites. I love Kadets, learned to fly on a Kadet Jr. in the 70's. I had a tough time learning on 3 channels though but did'nt know better until I flew an aileron equipped Ace alpha 15. Now that was fun! I've saved rudder only skills for gliders. Anyway, I want to scratch build something 1/2 A for a Norvel .061 that I'm going to have to buy myself since santa screwed me over and brought me a Zenoah instead.
If it turns out good, maybe I'll learn to scale it up so I can use the zenoah if not , I'll turn it into an edger or mount it on a bicycle. Please point me to the website that explains cad. I miss LS too.
goldy9955
Oh yeah, which button do I hit to post pictures?
Hide Signatures
       Post #: 46
RE: 1/2A trainer anyone? - 1/5/2005 7:59 AM
Bipe Flyer
Score: 105
Status: offline
I think that it would be best with 4 channels and a Norvel .074. DuBro makes a steerable nosewheel that should work nicely.
You don't need a CAD program to print it. It is already tiled in the PDF file or, if you prefer, I have a program that can resize it.
If you want a good CAD program that is easy to learn, try Turbocad. They used to have a free version at http://www.turbocad.com , but I can't find it there anymore. The free version I have is 5.1 from 1998, but you can get version 8 for around $10 on eBay.
1/2A all the way!
Club Saito #151
Hide Signatures
(in reply to goldy9955)
       Post #: 47
RE: 1/2A trainer anyone? - 1/5/2005 8:38 AM
BMatthews
Score: 247
Last Login: 6/18/2013
Status: offline
Hey Bipe, what about a mod page with a conventional gear? I've always prefferred conventional as I feel it's tougher in a hard landing and sure doesn't transfer the shock to the rudder servo like a nose gear does in a tough one. Some of the folks looking to build may prefer that option.
It's nice to see that extra size and wing area to help slow it down too. And finally a suggestion that folks start with a 7x3 to further help slow the model down as well.
Witty saying to be plagarized shortly.....
Hide Signatures
       Post #: 48
RE: 1/2A trainer anyone? - 1/5/2005 9:18 AM
Bipe Flyer
Score: 105
Status: offline
IMO, the only thing that a trike has over a taildragger is that it is easier to learn takeoffs with. To make it a taildragger, just move the mounting blocks for the mains up to the second former.
With an .074, a 7X3 is definitely the right choice.
1/2A all the way!
Club Saito #151
Hide Signatures
(in reply to BMatthews)
       Post #: 49
RE: 1/2A trainer anyone? - 1/5/2005 9:36 AM
Rendegade
Score: 105
Status: offline
Can I ask why you decided to make it 4 channel?
I would have thought a nice 3 channel job would have made it a easy flier.
More dihedral makes for less stress
It''''s easy to fly, just throw yourself at the ground and miss!
Hide Signatures
       Post #: 50
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.984RCU1
