The "LST" is a nice choice -- Lynn was partial to the high wing Simple Series -- I think he would like it. He flew the 1/2A SST, so why not the 1/2A LST.
_____________________________
the "other" andrew I'm not older than dirt, but I can remember when it was patent pending
WI, USA Status: offline
You can find more info on Tile Printing and the program on the following site. Also some GREAT free plans to. For the tile print info scroll towards the bottom. Hope this helps! http://my.pclink.com/~dfritzke/ Joe
Lots o Planes & Helicopters. 5 more planes & 1 heli to build ;)
No problem. Yep, he's got lots of nice old time plans posted. Gonna have to build some, one of these days. Some are tiled too, and the best part, they are free. Very nice of him to do that
What type of wood do you use for the sides of the fuse.? Theres some Balsa 1/8" sheet, and theres 'Lite ply' 1/8" plywood. The plywood sure is expensive though. 12 bucks(Canadian) for a 12"x 48" piece. maybe I'll stick with balsa if theres no strenght issues with using it.
Oh...and what type of glue do you use(havent built a plane before)? I have some medium CA glue. do I need any epoxy or will it hold with just the CA?
< Message edited by adr_ian64 -- 1/4/2005 12:20:51 AM >
The plans show 3/32" balsa. Only use plywood for the firewall and balsa everywhere else. Also add a couple of pieces of tri-stock behid th firewall Only use CA, you shouldn't need any epoxy for this plane except maybe the firewall. If you build it with ailerons, put .75" dihedral on each wing tip. If you build it without ailerons, use 1.75" diheadral on each tip.
