D Bronk
MB, CANADA Status: offline
Well I had the Trainer moving on its` own power thi evening.Got about a 12' taxi in, when the 1st bug, showed up.Nothing to serious, but it has to be addressed first.Basically ,I had a prop strike, with the nose ski.I forgot to take into account ,the ski tip rising and falling ,with its` rubber suspension..I`ll simply lower the entire nose gear, and give the prop extra clearance from the ski.I got a late start today, so that was the only test..But I learned a couple things .The skis glide very,nicely..THE NORVEL, HAS a Lot , OF , SNOT !!!! This plane should have no problem ,in a ROS..Temp. is supposed to be hanging around 0'C. tomorrow,hopefully no more bugs..
_____________________________
Dave B. ------ Corsair Brotherhood # 11------- I am a,#11,cause,,I`m 10% Better,than a perfect "10".
