D Bronk
MB, CANADA Status: offline
..Good News,(GN) Bad news,(BN) ; .GN:Got the engine running ,today .BN:It ran, So,so .GN;The LST trainer, can get airborne, in 15' .BN;can be put, back on the ground ,in about, 15 more feet. . .GN;It flies. .BN;It didn`t fly, very far,and crashed. .GN; It came down ,from only 6', to 8' height,with NO,Damage. . .BN;The engine, just Quit,causing a, pre-mature, touch down,left wing tip first. .GN;I started it again, and found the problem. .BN;The fuel lines seem loose, and,I see bubbles, in the feed line@the Carb.They need attention,and,they`re only,a few weeks old .GN;I have more line . .BN;No video. .GN;Might be able, to ,get my Neighbour, Betty, to work the Camera, for me tommorow.. .BN;I have to fix HER, Sewing Machine, First .GN; Plane will ,Get Airborne ,with my aluminum skis, on it BIPER; The Best,GOOD NEWS,is,I think this plane ,will be a Real CHAMPION.Good job on the design.. IT has,,Lots of power ,with the 0.074"on it, even though there`s a few bugs, to work out first.I haven`t played with any props except for the 7"x 4"..I`ve decided that, before, I try To go airborne with this plane,again, and risk Damage..I want to see it run, 2 more ,full Tanks,on the ground,taxiing, with out it missing a beat .I need to regain, Faith in it first.Then, the wing, will go back on.Hopefully ,I can do this tommorow..DAVE B.
_____________________________
Dave B. ------ Corsair Brotherhood # 11------- I am a,#11,cause,,I`m 10% Better,than a perfect "10".
