RE: 1/2A trainer anyone?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> "1/2 A" & "1/8 A" airplanes >> RE: 1/2A trainer anyone? Page: <<   < prev  22 23 24 25 26 [27] 28 29 30 31   next >   >>
Login
RE: 1/2A trainer anyone? - 4/27/2006 5:26:03 AM
gcedillo
Status: offline
Already cut, made hinge slots and covered rudder and stabilizer, no photos yet (`till I figure a trim scheme), also made aileron torque housing,those little details take time (since is the first time I make this).
< Message edited by gcedillo -- 5/1/2006 10:53:59 PM >
(in reply to KidEpoxy)
       Post #: 651
RE: 1/2A trainer anyone? - 5/1/2006 10:53:33 PM
gcedillo
Status: offline
aileron torque rods installed
Now some questions:
1.-Can I install the aileron servo on one side of the center ribs as not to weaken the middle joint? (this is not cutting a square space in the middle ribs but in either side of the middle?).
2.- Wich servo will do I have both futabas 3004 and hitec hs 88 I`ll use a .15 os max .15 fp. ( I know I havent weighed this thing yet).
Click to see fullsize image.
Click for fullsize
< Message edited by gcedillo -- 5/1/2006 10:57:52 PM >
(in reply to gcedillo)
       Post #: 652
RE: 1/2A trainer anyone? - 5/1/2006 11:08:08 PM
Bipe Flyer
Status: offline
If yo need to you can put it to one side, but you might get assymentrical movement between the two ailerons.
I'm not familiar with the HS88, do you mean HS81 or HS85 maybe? Either way, if it is smaller than the S3004, then use it.
_____________________________
1/2A all the way!
Club Saito #151
       Post #: 653
RE: 1/2A trainer anyone? - 5/2/2006 12:24:21 AM
gcedillo
Status: offline
Youre right they are HS 81, being smaller they`ll require a smaller cut out.
Thank you Bipe
(in reply to Bipe Flyer)
       Post #: 654
RE: 1/2A trainer anyone? - 5/2/2006 1:06:29 AM
gcedillo
Status: offline
I already made cuts for the HS 81, it´s shallower only I´ll add 1/4 of an inch hardwood to screw the servo and leave more rib area glued together.
fuel proofed the fuselage, made aileron hinges and slits.
Click for fullsize
< Message edited by gcedillo -- 5/4/2006 3:46:07 AM >
       Post #: 655
RE: 1/2A trainer anyone? - 5/4/2006 2:34:22 AM
gcedillo
Status: offline
The wing is finished, now to cover .
On the fuse install servo rails, and cover, and then glue empenage.
Click for fullsize
       Post #: 656
RE: 1/2A trainer anyone? - 5/4/2006 4:39:46 AM
Bolio
Status: offline
That plane looks great Cedillo, let me congratulate you for taking your son at such young age interested in this great hobby.
Good look on the maiden.
Saludos.
< Message edited by Bolio -- 5/4/2006 4:47:30 AM >
Jose A. Hernandez
ProBro#516
       Post #: 657
RE: 1/2A trainer anyone? - 5/7/2006 6:57:39 AM
gcedillo
Status: offline
Got a lot of work
Covered the fuse (only need to make windows)
Click for fullsize
(in reply to Bolio)
       Post #: 658
RE: 1/2A trainer anyone? - 5/7/2006 7:17:24 AM
Bipe Flyer
Status: offline
It's coming along nicely. At this rate you'll be flying before Dave.
Where is Dave anyways, anyone heard from him lately?
1/2A all the way!
Club Saito #151
       Post #: 659
RE: 1/2A trainer anyone? - 5/7/2006 10:08:29 AM
gcedillo
Status: offline
The windows came out a bit funny, but I want to fly it soon so theyll stay.
Click for fullsize
       Post #: 660
RE: 1/2A trainer anyone? - 5/7/2006 3:27:12 PM
KidEpoxy
Status: offline
Cedillo-
Plane is coming along nicely, way to go
Just dont put skis on it or you will disapear like Dave
......saw Dave posted in Warbirds a week or 2 ago, I PM'ed him to stop by 1/2A & say hi....no response
Optional MA is part of AMA history, we can go optional AGAIN if we just say so
       Post #: 661
RE: 1/2A trainer anyone? - 5/24/2006 7:40:14 AM
Bipe Flyer
Status: offline
Any more progress?
1/2A all the way!
Club Saito #151
       Post #: 662
RE: 1/2A trainer anyone? - 6/12/2006 10:14:06 AM
tommot
Status: offline
hey does anyone fly control line here
im looking foor good planes for a norvel 0.61 ama
its a litle screamer
(in reply to D Bronk)
       Post #: 663
RE: 1/2A trainer anyone? - 6/26/2006 4:36:36 AM
JasonRP
Status: offline
I don't think the windows are bad at all- if it were me, I'd add another triangle to the front window, starting from the existing front corner of the side window, and extending down, so that the rear side is as wide as the square window next to it.. Make sense?
It looks great by the way- I wish I could cover that well!
Jason
Play PINBALL!!
       Post #: 664
RE: 1/2A trainer anyone? - 7/4/2006 6:25:59 PM
