AXI 2208/34 on 3cell problem, HELP    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Electric Aircraft Universe >> 3D Electric Flying! >> AXI 2208/34 on 3cell problem, HELP
Page: [1]
Login
AXI 2208/34 on 3cell problem, HELP - 10/30/2004 9:27 PM
shannah
Score: 105
Last Login: 5/18/2013
Status: offline
I have a AXI 2208/34 running 3 cell Kokam 1020 mah. Jeti Advance 08 3P controller. APC 10x4.7 or APC 9x3.8. Problem is this: After about 2-3 minutes of flying the motor starts pulsating and won't go to full power. Both of my battery packs behave the same way. Switched to a 2 cell and it did the same thing. Is the controller too small??? I ran this on my shockflyer and didn't have this problem (2 cell). Any thoughts????????
Hide Signatures
       Post #: 1
RE: AXI 2208/34 on 3cell problem, HELP - 10/30/2004 10:11 PM
YS-I-DO
Score: 105
Last Login: 1/9/2006
Status: offline
Get a bigger ESC. The 3 cell will pull more amps than a 2 cell. I ran a Phoenix 25 on my 2208, and had no problems at all with 3 cell.
_____________________________
I'm not lucky, I'm [i]just that good.[/i]
Hide Signatures
(in reply to shannah)
       Post #: 2
Geistware
Score: 100
Last Login: 5/2/2008
Status: offline
I have this same setup and will be interested in the responses.
Aircraft Proving Grounds
http://www.rcaircraft.net/
Information on the building and flying of Radio Control Aircraft.
Site for hobbyist in the R.C. Aircraft modeling world.
Hide Signatures
       Post #: 3
RE: AXI 2208/34 on 3cell problem, HELP - 10/30/2004 11:13 PM
thedak
Score: 100
Last Login: 6/23/2012
Status: offline
A 2208/34 with a Jeti 8P is fine. You don't need a bigger ESC. It doesn't even get warm on a 3 cell pack and a 9 X 3.8 PRop.
Hide Signatures
(in reply to Geistware)
       Post #: 4
RE: AXI 2208/34 on 3cell problem, HELP - 10/30/2004 11:33 PM
bob_nj
Score: 105
Last Login: 5/9/2013
Status: offline
Well then, maybe the real question is what amperage is shannah pulling, and why?
Hide Signatures
(in reply to thedak)
       Post #: 5
RE: AXI 2208/34 on 3cell problem, HELP - 10/31/2004 7:26 AM
thedak
Score: 100
Status: offline
To big a prop.
2208/34
9x3.8 on a 3 cell
10x4.7 on a 2 cell
Hide Signatures
(in reply to bob_nj)
       Post #: 6
RE: AXI 2208/34 on 3cell problem, HELP - 10/31/2004 7:33 AM
shannah
Score: 105
Status: offline
I ran the 9x3.8 and it did the same thing.
Hide Signatures
       Post #: 7
RE: AXI 2208/34 on 3cell problem, HELP - 10/31/2004 7:59 AM
b-mccor8
Score: 100
Last Login: 6/29/2011
Status: offline
I am running a jeti 18, axi 2208/34 with a apc 10 x 4.7 3 cell 10-12c. Flys roughly 15 minutes, no power problems. Cannot get the plane to fly right though. Knife edge and inverted problems?
The wife said,"If you go flying one more time I'm Leaving you". Man, I'll miss her??
Hide Signatures
       Post #: 8
RE: AXI 2208/34 on 3cell problem, HELP - 10/31/2004 8:10 AM
shannah
Score: 105
Status: offline
Guess my ESC is too small. Darn. It was the setup I ran on my shocky, guess I didn't have to go full bore with that as much as I do with the Raptor.
Hide Signatures
(in reply to b-mccor8)
       Post #: 9
RE: AXI 2208/34 on 3cell problem, HELP - 10/31/2004 8:31 AM
YS-I-DO
Score: 105
Status: offline
Something I just thought of. I had my ESC programmed for a 9 volt cutoff (3 cells). I tried running a 2 cell pack and the motor would run up, then die, over and over. If the Jeti is programmable, check to see if you voltage cutoff is too high.
Hide Signatures
       Post #: 10
RE: AXI 2208/34 on 3cell problem, HELP - 10/31/2004 9:35 AM
Airbike
Score: 100
Last Login: 5/15/2013
Status: offline
My 2208/34 w/9x4.7 prop pulls about 12 amps at WOT, on 3cell 1200 Etec pack rated at 10C.
You need to make sure that your battery is up to it. If you have one of the earlier packs, they were not rated for much amp draw.
See if you can borrow someone's TP1320 pack to check your setup.
The more you put into living, the more you get out of life.
Revver #150
Hide Signatures
(in reply to YS-I-DO)
       Post #: 11
RE: AXI 2208/34 on 3cell problem, HELP - 10/31/2004 2:46 PM
Magnum9
Score: 100
Last Login: 6/20/2008
Status: offline
I have the 2208/34 running the APC 9x3.8 in an 11 ounce AUW EPP plane with the Jeti Advance 08 and have had no problems. That combo will pull almost 9 amps static, but on my setup full throttle goes vertical until you can't see it in under 15 seconds, so you don't pull that many amps all the time. The 10x4.7 is really too big for 3 cells.
I run E-tec 3S-700 7.5C packs and 3S-1200 8.5C packs and they both handle the current no problem. The 700 packs get quite warm, but nothing extreme. The 1200 pack, having lower internal resistance, gives more static RPM and better vertical, but is 30 grams heavier.
Check if the motor is getting warm, mine is still cold after running three packs through it. Check that you have the correct timing setup on the Jeti for the AXI. It is weird that you say you ran the same setup on another plane without any problems. The ESC is not too small, don't go and buy another one, you don't need to. The weight of the plane doesn't matter because the current ratings you see are static. If my setup pulls 9 amps static, then pulling 11 ounces around it probably only sees 7 amps at full throttle most of the time.
Hide Signatures
(in reply to Airbike)
       Post #: 12
RE: AXI 2208/34 on 3cell problem, HELP - 10/31/2004 3:43 PM
Geistware
Score: 100
Status: offline
I can you tell if a 3 cell setup is too big or not. I have everything I need except the plane and I want to do some tests to make sure that everything is ok. Do you just run the engine at WOT and measure the current?
Hide Signatures
(in reply to Magnum9)
       Post #: 13
RE: AXI 2208/34 on 3cell problem, HELP - 10/31/2004 4:11 PM
bipeaddict
Score: 100
Last Login: 3/12/2013
Status: offline
It sounds like your BEC is overheating and causing the motor to cut out. You can't size an ESC on amperage calculations only if you are running the BEC enabled.
There is a direct correlation between the size of the ESC, number of cells in the battery, number of servos and type, and the BEC.
Here is cell count for a CC Phoenix 25 (Can handle 25 Amps). A 3 cell lipo pack is borderline between the 7-8 and 9-10 columns.
Servo Ratings with BEC Enabled
Servo Type 5-6 cells 7-8 cells 9-10 cells
Standard (micro) servos 4 4 3
High Torque (micro) servos 4 3 2
The JETI 18 will support a fewer number of servos.
How many servos are you running? What type? Some servos pull way more amperage than a std GWS pico.
If you setup runs with the motor not cutting out with the servos disconnected then it is your BEC overheating.
Hide Signatures
       Post #: 14
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.469RCU1
