OS VZB V-SPEC
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC 1/8th Scale Buggies >> OS VZB V-SPEC
Page: [1] 2 3 4   next >   >>
Login
OS VZB V-SPEC - 10/31/2004 7:13:28 AM
mgreen
Status: offline
I'm slowly putting this thing together for my Hyper 7 Pro. I went with the Jammin P1 part # 10055 pipe because it will deliver bottom to mid-range power. And thats what I need around here; Most of the tracks are small. I also have an Ofna 086 pipe and it seems like it is mid to top-end.
Click to see fullsize image.
Click for fullsize
Click for fullsize
< Message edited by mgreen -- 10/31/2004 7:29:21 AM >
       Post #: 1
RE: OS VZB V-SPEC - 10/31/2004 7:24:37 AM
mgreen
Status: offline
A few more pictures. I always end up having problems with the nut that holds the clutch-bell to the crank. If I tighten it down to much, the bearing fills notchy. If its to loose, then it will unscrew itself under the RPMs. What are you guys using. Small small washers that fit into the hole of the bearing so it would take up the spacing between the two bearing, inside the clutch-bell, so you can tighten the screw down and it not put any tension on the bearings.
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to mgreen)
       Post #: 2
RE: OS VZB V-SPEC - 10/31/2004 7:27:13 AM
impulse
Status: offline
Sick engine.
       Post #: 3
RE: OS VZB V-SPEC - 10/31/2004 7:28:00 AM
Neil 777
Status: offline
I just fitted mine in to my 777 yesterday, can't say that I had any trouble with mine just using the standard kyosho alloy clutch setup.
       Post #: 4
RE: OS VZB V-SPEC - 10/31/2004 7:33:31 AM
sh0wtime
Status: offline
where did you get your OS from Neil??
i had one on order from Russ for ages & got a Bergo P5 instead
(in reply to Neil 777)
       Post #: 5
RE: OS VZB V-SPEC - 10/31/2004 8:06:00 AM
madmaniac
Status: offline
The V-SPEC is truly a monster and so easy to tune i have used the stock alloy clutch setup for the whole season and it has worked flawlessly except for one time when one of the clutch springs broke but it was probably my fault.
(in reply to sh0wtime)
       Post #: 6
RE: OS VZB V-SPEC - 10/31/2004 9:02:55 AM
maxmod
Status: offline
for the whole season lol
you have only raced once but the stock clutch setup will work great.
_____________________________
Mbx-5 with rody c5
what a powerhouse
(in reply to madmaniac)
       Post #: 7
RE: OS VZB V-SPEC - 10/31/2004 10:25:44 AM
Neil 777
Status: offline
quote:
ORIGINAL: adamshowtime
I got it from rc-mushroom, I'd seen you say that russ was having trouble getting them.
       Post #: 8
RE: OS VZB V-SPEC - 10/31/2004 1:34:40 PM
mgreen
Status: offline
Is this motor considered ROAR legal? I know it only has 3 ports but I'm not to sure about the turbo-plug.
       Post #: 9
RE: OS VZB V-SPEC - 10/31/2004 4:06:57 PM
zzman
Status: offline
all i got to say is mine has going on 4gal run on it and still like the day i got it. for the first gal. i heated it up before i started it to save on the stress of the conrod. it flies and used a hyper standard clutch set-up w/ carbon shoes. www.fullthrottlehobbies.com has them for $260 now.
tell FRANKIE- PETE sent you ...
IN THIS HOBBY-MONEY SOLVES EVERYTHING!
       Post #: 10
RE: OS VZB V-SPEC - 10/31/2004 4:17:05 PM
dryvr
Status: offline
I have the v-spec on order and i'm going to use a jp1 pipe as well. I've never had a turbo engine, what plugs should I use?
(in reply to zzman)
       Post #: 11
RE: OS VZB V-SPEC - 10/31/2004 4:26:49 PM
sh0wtime
Status: offline
quote:
ORIGINAL: ultranewb
you'll need to use turbo plugs
turbo is just a different way of the plug sealing against the head.
a regular plug you use a copper washer under the head of the plug but a turbo plug has a built in taper that seals up tight against a corresponding taper in the head button
and if you do em up tight you have a right old time trying to get them out again
(in reply to dryvr)
       Post #: 12
RE: OS VZB V-SPEC - 10/31/2004 4:29:25 PM
dryvr
Status: offline
Thanks for the info adam.
       Post #: 13
RE: OS VZB V-SPEC - 10/31/2004 4:29:45 PM
zzman
Status: offline
use OS P3's they are the plug to use. this motor needs a hot plug. you can get packs of 6 at
www.rc-mushroom.com they are cheap-$25 if you get them at your LHS they cost around $8 each. so you save big time...
(in reply to dryvr)
       Post #: 14
RE: OS VZB V-SPEC - 10/31/2004 4:33:52 PM
dryvr
Status: offline
hyper, that website has contact info in hong kong, any U.S. websites that sell them?
(in reply to zzman)
