papermache
Joined: 9/26/2002 From: Gary, IN, USA Status: offline
xplayer, The kit version has a balsa fuse and uses an embedded bellcrank & pushrod to activate the full flying stab/elevator. The ARF has a fibreglass fuse and uses a micro servo mounted in the tail to activate the stab. It requires a long extension lead which some people say leads to interference or chatter problems. I've had no problem with my 2-piece wing, although I can see an argument for a three-piece. Spoilers would be a good idea. I don't have them on mine, but I wish I did. Construction is fairly straightforward, although there is a LOT of it. I had some trouble figuring out what the instructions were saying at times, especially around the wing joiner. If you can build a Sterling kit, you shouldn't have any trouble with a BOT. papermache
_____________________________
Slope Gliding - A Northwest Indiana tradition since 1896
