Feather Receiver & Sanwa Tx
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Radio Manufacturer Direct Support >> Hitec/MultiPlex Radios- Ask Hitec Customer Service >> Feather Receiver & Sanwa Tx
Page: [1]
Login
Feather Receiver & Sanwa Tx - 8/14/2002 3:23:23 PM
bitmaniac
Status: offline
Hi! Mike
First of all here is my Configuration:
Tx Sanwa (old) Pcm 6p 6channel 41Mhz (41.020Mhz crystal)
Rx Hitech Feather receiver /Single conv. 40Mhz (41.020 crystal)!
I use the above configuration to fly my LiteStik
The problem is that I have a dramatically reduced range (18-20meters)
As you have noticed I'm using my Sanwa Rx crystal at 41.020Mhz
although the hitech feather is at 40Mhz range!
I was thinking that was not a problem (or MAY BE IT IS?)
Would it be better to have a hitech crystal at 40Mhz range (on the receiver) and put a 40Mhz range on my Sanwa Tx too??
PS: what exactly is the job for theese crystals, as
I can figure out they have the roll of some kind of "filltering"
for the oscillator circuit on Rx & Tx?
Regards,
Alexander
GREECE
       Post #: 1
Feather Receiver & Sanwa Tx - 8/14/2002 8:37:37 PM
MikeMayberry
Status: offline
I would suggest you use the Hitec single conversion crystal only. This may solve your problem.
Mike.
(in reply to bitmaniac)
       Post #: 2
Feather Receiver & Sanwa Tx - 8/16/2002 12:29:40 PM
bitmaniac
Status: offline
Hi! Mikle
Thanks for you great help my frind!
a last question,Mike:
Do you suggest that I could use 41Mhz band hitech crystal (so I don't change my Tx crystal) ,although it is a 40Mhz receiver?
Have a nice day
Alexander
       Post #: 3
Feather Receiver & Sanwa Tx - 8/19/2002 9:51:48 PM
MikeMayberry
Status: offline
If it is 40mhz then changing to 41mhz will affect the performance.
Mike.
       Post #: 4
Feather Receiver & Sanwa Tx - 9/2/2002 3:01:15 PM
bitmaniac
Status: offline
Hi! Mike
Here we are ...back again!
After a loong search to find a suitable crystal to match hitec feather receiver to my Sanwa Transmitter I come to the following
conclusion:
My hitec has a 40.675Mhz crystal. The only Sanwa crystals I have found is 40.670 , 40.680 ,e.t.c (10Khz step)
I also noticed that hitec crystal is at 40.675 ...50.685. e.t.c
Is that right??? or I miss something???!!!??
Thanks Mike
What solution Do you suggest?
_____________________________
the old C=64 team!
       Post #: 5
Feather Receiver & Sanwa Tx - 9/4/2002 1:40:10 PM
bitmaniac
Status: offline
Mike,
Is there a way of finding a 41.020Mhz Hitec crystal (single conv.)
or a 40.670Mhz one? (I own an original 40.675Mhz hitec crystal)
or ,is there a way of re-tuning my feather receiver at 41Mhz band?
Alexander
the old C=64 team!
       Post #: 6
Feather Receiver & Sanwa Tx - 9/11/2002 2:11:38 AM
MikeMayberry
Status: offline
Since we don't import any 40mhz equipment into the US, I don't know. Where do you live?
Mike.
       Post #: 7
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.438RCU1
