RE: Official Mayhem Thread
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC 1/8th Scale Buggies >> RE: Official Mayhem Thread
Page: <<   < prev  11 12 [13] 14 15 16 17 18 19 20   next >   >>
Login
RE: Official Mayhem Thread - 6/17/2005 8:36 PM
ProfitOfDoom
Score: 100
Last Login: 4/25/2009
Status: offline
Yea,I guess how anal your track owners are.Its cool at mine its just plain and simple 1/8th scale class.Engines dont matter
Hide Signatures
(in reply to JustinWZP)
       Post #: 301
RE: Official Mayhem Thread - 6/20/2005 2:58 AM
176RRT
Score: 100
Last Login: 7/15/2006
Status: offline
Hey guys.. I was just wondering if the Mayhem has a pullstart as an option instead of the rotostart plate? I really don't like rotostarts that much and would prefer a P/S instead. I have better luck starting an engine w/ a p/s. My 9.5 MBX starts w/ 1 or 2 pulls most of the time. My mayhem is being delivered tomorrow and I can't wait so i fugured i should ask this question just in case I needed to order another part.. Thanks
Hide Signatures
(in reply to ProfitOfDoom)
       Post #: 302
RE: Official Mayhem Thread - 6/20/2005 3:15 AM
176RRT
Score: 100
Status: offline
Sorry guys forget it, I found the part at Horizon.
Hide Signatures
(in reply to 176RRT)
       Post #: 303
RE: Official Mayhem Thread - 6/20/2005 9:27 AM
RCDadChicago
Score: 100
Last Login: 4/14/2006
Status: offline
Hi all, I just got a used Mayhem and have been reading posts here to learn more.
I have the Team Associated XP2 radio and when you turn the switch on the green (full) light flashes and it rapidly beeps, anyone ever seen that?
Another question, the red piece between the engine and the manifold you see in this picture is worn out on mine, anyone know what that piece is called and where I can get another?
< Message edited by RCDadChicago -- 6/20/2005 9:42 AM >
_____________________________
http://dads-toy.com
Hide Signatures
(in reply to Giles300-72)
       Post #: 304
RE: Official Mayhem Thread - 6/20/2005 2:10 PM
Ram008
Score: 100
Last Login: 3/20/2010
Status: offline
It's an exhaust manifold gasket. You should be able to pick up a Sportwerks/Dynamite one from a local hobby shop, or GS Racing makes them as well.
Hide Signatures
(in reply to RCDadChicago)
       Post #: 305
RE: Official Mayhem Thread - 6/20/2005 3:33 PM
RCDadChicago
Score: 100
Status: offline
I found out there is a simple solution (after calling Associated) as to what is wrong with my Tx....it's busted
It looks like this one, is the manifold gasket I need, is that a pretty good asumption?
EDIT: Found out that is the right gasket so its on the way.
< Message edited by RCDadChicago -- 6/21/2005 3:34 PM >
http://dads-toy.com
Hide Signatures
(in reply to Ram008)
       Post #: 306
RE: Official Mayhem Thread - 6/21/2005 8:46 PM
joes75
Score: 100
Last Login: 4/13/2009
Status: offline
I just picked up a sportwerks 26 engine for my H7 and was curious as to how the carb insert is removed from the carb. It came with one preinstalled already in the carb, does it screw out or just pull right out,I didnt want to mess up the carb so I posted here first also what is the most common insert to use the 6.5,7.5 or 9mm is there really that much of a power difference? The manual says the 9mm insert is for the most power and makes the buggy hard to control is this true?..thanks
HYPER 7 PCR (SW 26 v2), OFNA 9.5 C-HUB (MACH 28), HPI SAVAGE SS (MACH 28), MUGEN MBX5T MSR(OS 30), HPI RS4 3 EVO(in pieces)
Hide Signatures
(in reply to pkguns)
       Post #: 307
RE: Official Mayhem Thread - 6/21/2005 9:11 PM
moose24
Score: 100
Last Login: 3/29/2007
Status: offline
It pulls out. There is more power with the 9mm. It just takes some practice to control the throttle.
Hide Signatures
(in reply to joes75)
       Post #: 308
RE: Official Mayhem Thread - 6/22/2005 3:39 PM
rwong21
Score: 100
Last Login: 5/27/2007
Status: offline
Hi all, Where I can find a on-line manual of the sportwerk motor .26? I want to know how to rebuild or change some part (for example clutch, carbuletor, etc.) of the motor. In the RTR manul only show a page of information. Maybe when some one buy the separete motor...it include more information.
Hide Signatures
(in reply to moose24)
       Post #: 309
RE: Official Mayhem Thread - 6/22/2005 9:29 PM
Tony LST05
Score: 100
Last Login: 3/2/2007
Status: offline
quote:
ORIGINAL: rwong21
Horrizon website
http://www.horizonhobby.com/Shop/ByCategory/Product/RelatedParts.aspx?ProdID=SWK8085&Category=Parts+Listing&SubCategory=
Hide Signatures
(in reply to rwong21)
       Post #: 310
RE: Official Mayhem Thread - 6/22/2005 11:36 PM
rwong21
Score: 100
Status: offline
Thk U Tony LST05
I'm blind person
Another Hand...this is in reference of the steering servo.
What is better Z8800 Digital Hi-Torque Surface (JRPSZ8800T) or Airtronics 94358 High Torque Servo (AIR94358Z)?
Hide Signatures
(in reply to Tony LST05)
       Post #: 311
RE: Official Mayhem Thread - 6/23/2005 1:24 AM
rwong21
Score: 100
Status: offline
Aluminum Rear Inner Suspension Mounts
For the final of this month I see this new items Aluminum Rear Inner Suspension Mounts with anti-squat adjustment of 0, 1, and 3
degrees. My question is: What is the benefit to change the degrees?
Hide Signatures
       Post #: 312
RE: Official Mayhem Thread - 6/23/2005 4:14 AM
Tony LST05
Score: 100
Status: offline
quote:
ORIGINAL: rwong21
Thk U Tony LST05
I'm blind person
I would go with the JRPSZ8800T. That is a great servo!!!
Hide Signatures
       Post #: 313
RE: Official Mayhem Thread - 6/23/2005 6:52 AM
JustinWZP
Score: 100
Last Login: 6/28/2007
Status: offline
I own three of those 94358's and two of the 8800T's. You should purchase the JR 8800T......It is a better servo. The stats don't look as good but the performance difference is very noticable compared to the 94358.
I'm puting those 94358's up for auction tomorrow if anyone is interested. Just search for: 94358
Hide Signatures
       Post #: 314
RE: Official Mayhem Thread - 6/23/2005 4:53 PM
rwong21
Score: 100
Status: offline
Hi Justin:
Where you buy JR 8800T?
Hide Signatures
       Post #: 315
RE: Official Mayhem Thread - 6/23/2005 6:44 PM
JustinWZP
Score: 100
Status: offline
Southeastrc.com
Hide Signatures
       Post #: 316
RE: Official Mayhem Thread - 6/23/2005 7:25 PM
MorganSS
Score: 100
Last Login: 7/14/2008
Status: offline
Ive torn my mayhem apart and loctited all that should be...
Got everything ready to break her in tonight, I cant wait, this thing is going to be a beast
MBX5 PROSPEC race machine
RC10GT OVAL/OFFROAD
Hide Signatures
       Post #: 317
RE: Official Mayhem Thread - 6/24/2005 12:32 AM
zimzalahbim
Score: 100
Last Login: 1/6/2010
Status: offline
does anyone know if ofna pivot balls will fit the mayhem? thanks
Hide Signatures
(in reply to MorganSS)
       Post #: 318
RE: Official Mayhem Thread - 6/24/2005 12:56 AM
MorganSS
Score: 100
Status: offline
I couldnt start mine up! It filled the exhaust with unused fuel, it tried a couple of times to run but when I removed the starter it died within seconds HELP
RC10GT OVAL/OFFROAD
Hide Signatures
(in reply to zimzalahbim)
       Post #: 319
RE: Official Mayhem Thread - 6/24/2005 2:12 AM
MorganSS
Score: 100
Status: offline
good news, leaned it up just a little and finally found the right combo, ran 1 tank through at idle sitting on a stand, did a FLAWLESS job WOOT This little girl is going to be a BEAST
RC10GT OVAL/OFFROAD
Hide Signatures
       Post #: 320
RE: Official Mayhem Thread - 6/24/2005 9:00 AM
176RRT
Score: 100
Status: offline
Hey guys.. I just broke in my mayhem today and I have to say that this buggy is great. The buggy fired right up and I was very impressed w/ the rotostart. This is my first rotostart unit and I was actually not too sure if I should have bought the pullstart unit and ditch the rotostart. Thank goodness I didn't cuz the mayhem fired right up each time.. Even my girlfriend started the engine and it was her first time trying! I put 3 tanks through her today. The only thing I had to do w/ the engine was to lean out the HSN alittle cuz the engine would cut off whenever I hit the throttle. I drove around for the first 3 tanks mantaining temps. between 195 - 205..
The engine is really good and the 053 pipe is really silent. That would have to change since I have a JP-2 pipe on the way. I was impressed overall w/ the quality and the handling and even the stock steering servo was more than adequate. I'll probably keep the stock servos because I only bash and do not race as of now.. The advice on this thread is great guys, keep it up.. It's one of the reasons why I chose this buggy.. See ya
Hide Signatures
       Post #: 321
RE: Official Mayhem Thread - 6/24/2005 2:35 PM
RCDadChicago
Score: 100
Status: offline
I'll be glad when I see mine go down the street the first time. Since I bought it used the first thing I did was tear it completely down, clean, regrease, replace screws and learn how it goes together. I've been working on it for a week now after work.
http://dads-toy.com
Hide Signatures
       Post #: 322
RE: Official Mayhem Thread - 6/24/2005 7:09 PM
176RRT
Score: 100
Status: offline
By the looks of your Mayhem RCDadChicago, it looks pretty much brand new except some scratches on the heat sink head.. Nice pick up! Good luck w/ your buggy. I had a blast my first day.
Hide Signatures
       Post #: 323
RE: Official Mayhem Thread - 6/24/2005 7:57 PM
fhm101
Score: 100
Last Login: 12/8/2008
Status: offline
Any word on the ST?
Hi, I'm FHM and I suffer from terminal tinkeritus.
Hide Signatures
       Post #: 324
RE: Official Mayhem Thread - 6/24/2005 8:38 PM
rwong21
Score: 100
Status: offline
ST is not yet for sell until final of June. You will need to wait who is the luckyman to try it first.
Hide Signatures
(in reply to fhm101)
       Post #: 325
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.563RCU1
