mhood
Joined: 2/9/2005 From: Jackson, MS, USA Status: offline
have you tried to adjust the exp. and the limit on the transmitter for the steering?, you can make it start toturn faster, which might make it touchier, and you can adjust it up to 125% on the limit, i found that with it set at 100% it doesnt turn as much as if it is set at 125%. the only other thing is the tires grip so much like on grass, the servo cant turn the tires as much, kinda like having no power steering on a real car. and its already supposed to have a high-torque servo on it. the only real problem i am having is with the interference i get from electrical sources, as in power lines or if i am in the house with the car off, just playing with the servos, everything is ok for about 15 seconds, then the throttle opens to about 20-30% and the wheels lock in the full left turn position. is there a frequency that i can change to is is it just a characteristic of the fm transmitter? and the reason i was going to use 10k oil in the diff is because where i play sometimes, i get hung on a root, dirt clod, etc... and if one frt tire and one rear tire is off the ground, the ones that are one the ground, dont turn.
< Message edited by mhood -- 3/22/2005 6:34:16 PM >
