FAO CEN: Gear ratios
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> CEN Racing >> FAO CEN: Gear ratios
Page: [1]
Login
FAO CEN: Gear ratios - 11/10/2004 4:55:48 PM
poor judgement
Status: offline
Hi,
i have fitted the gx1 2 speed to a cen rally, with 42/38 spurs and 16/20 pinions, could you give me an idea of whether my 18cv-r is likely pull these to ratios its full revs? baring in mind i am running 2.2" wheels and full spike tyres - motor is running well, i was aiming for a good 55mph...?
basically have i over geared it?
havent run it yet with these ratios due to waiting for parts, just interested in your opinion.
cheers
rob
_____________________________
http://homepage.ntlworld.com/robert.palmer97/CEN%20Test%20Pages/Mods%20to%20make%20a%20CEN%20semidecent.htm
       Post #: 1
RE: FAO CEN: Gear ratios - 11/10/2004 6:20:14 PM
Status: offline
Poorjudgment,
You should be fine. Actually you may want to go even taller on the pinions. Run it and see how it feels.
CEN RACING
Best Regards
CEN Racing - www.cenracing.com
(in reply to poor judgement)
       Post #: 2
RE: FAO CEN: Gear ratios - 11/11/2004 12:00:31 AM
poor judgement
Status: offline
hi, thanks thats good news
do u do taller pinions than the 20 tooth? if so do u have a part number please?
thats the tallest i could find. unless pinions from other cars or other manufacturers will fit on my clutch bell, i have the threaded type.
cheers
rob
(in reply to CEN Racing)
       Post #: 3
RE: FAO CEN: Gear ratios - 11/11/2004 6:38:17 PM
Status: offline
Poor Judgment,
that is the tallest that we make at this time for pinion gears. However, you can install smaller spur gears to gain more top end. I believe other pinion gears will fit as I have heard other customers using up to 25t pinions etc. Thanks.
CEN RACING
Best Regards
       Post #: 4
RE: FAO CEN: Gear ratios - 11/11/2004 7:33:47 PM
poor judgement
Status: offline
many thanks for that.
isnt the 38 tooth spur also the smallest that you manufacture?
is this a case of going elsewhere for the spurs too?
they are going to be a bit tricky to source i should imagine due to the design, unless the design is a standard throughout the manufacturers?
cheers for the help
rob
       Post #: 5
RE: FAO CEN: Gear ratios - 11/11/2004 8:59:59 PM
Status: offline
Yes 38 is the smallest spur gear that we make. Have you tried your current ratio yet? You should be good to go.
CEN RACING
Best Regards
       Post #: 6
RE: FAO CEN: Gear ratios - 11/11/2004 10:51:47 PM
Hands
Status: offline
You should be fine with the 20T pinion for your second speed. I have found that it takes a good distance to wind the engine out with the pinion. Make sure that your first gear pinion size is large enough to still mesh well. I would suggest you bump the first up to a 15T pinion.
       Post #: 7
RE: FAO CEN: Gear ratios - 11/12/2004 12:06:02 AM
poor judgement
Status: offline
the mesh is good thx, 15t would be too small, although isnt the ct4 a 15/20t arrangement? does this run with 42/38t spurs as well? im sure it does....well honestly my mesh does look fine - i will see how it runs when i finally get my silencer.....
cheers for the help folks
(in reply to Hands)
       Post #: 8
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.437RCU2
