Ethanol and MEthanol
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> RC Fuels >> Ethanol and MEthanol
Page: [1]
Login
Ethanol and MEthanol - 11/13/2004 12:59:15 AM
a-soares
Status: offline
From the quemist point of view they are very similar. Did anyone tried to run his glow engine using ethanol-oil mixtures? anyone thinks it's a good idea to give it a try?
I have an old Enya 15-IV lying around and i'm tempted to try, but have some fear it might damage the engine.
       Post #: 1
RE: Ethanol and MEthanol - 11/13/2004 3:36:40 AM
Homebrewer
Status: offline
It works best with ethanol.
(in reply to a-soares)
       Post #: 2
RE: Ethanol and MEthanol - 11/13/2004 2:52:39 PM
downunder
Status: offline
I think homebrewer meant methanol
They may work with ethanol because I think (but don't know for certain) that it will still react with the platinum in the coil. But I can't see the point unless you have your own moonshine still
Ethanol is for drinking. Methanol is to die for (literally!!).
Ohhhhh....Enya 15....use 25% all castor.
(in reply to Homebrewer)
       Post #: 3
RE: Ethanol and MEthanol - 11/14/2004 12:35:30 AM
Jim Thomerson
Status: offline
I think ethanol will run fine. I have the impression that the energy content is lower than methanol. So far as the glowplug keeping lit, I recently read an old article on control line team racer fuels. They ran all kinds of weird stuff in glowplug engines in search of both speed and range. I'll make a separate post on the article as it is an interesting read.
Jim
(in reply to downunder)
       Post #: 4
RE: Ethanol and MEthanol - 11/20/2004 2:43:38 AM
Mitty
Status: offline
It won't run on ethanol simply because there is gonna be no reaction between platinum and ethanol.
Methanol is what reacts And is to die for lol
_____________________________
http://aviaportal.net is biggest online community of avitors.
(in reply to Jim Thomerson)
       Post #: 5
RE: Ethanol and MEthanol - 11/20/2004 3:40:08 AM
Sport_Pilot
Status: online
The first Arden glow plugs were simple ni chrome elements, so platinum is helpfull but not absolutely necessary. Do a search on the engine conversion forum and you will find that some have run gas gas with glow plugs. You would have to experment with glow plug heat range. But unless you plan to run a still, methanol is a lot cheaper thanks to the tax. Even denatured ethanol costs more than methanol.
(in reply to Mitty)
       Post #: 6
RE: Ethanol and MEthanol - 11/20/2004 10:29:44 AM
coolguy234
Status: offline
I dont know the ratio of ethanol: methanol, but i know ethanol: petrol, its 1:2! I.e it'll take u 2 lts of ethanol to produce the same power as 1 lt of petrol!
Ethanol may b expensive for now, but oil prices are climbing, if it continues, methanol will follow!
(in reply to Sport_Pilot)
       Post #: 7
RE: Ethanol and MEthanol - 11/20/2004 10:36:48 PM
Sport_Pilot
Status: online
Methanol is made from natural gas, which is also rising.
(in reply to coolguy234)
       Post #: 8
RE: Ethanol and MEthanol - 11/21/2004 10:26:33 AM
coolguy234
Status: offline
Thats it, if the engineers there design rc running on ethanol, well it'll b very cheap here, we grow sugar cane and produce ethanol! We even export it!
       Post #: 9
RE: Ethanol and MEthanol - 11/21/2004 12:07:12 PM
Rupurt
Status: offline
Unfortunately ethanol can only be distilled to 96% after which it has to be chemically dried
       Post #: 10
RE: Ethanol and MEthanol - 4/22/2005 10:09:27 AM
canardlover
Status: offline
Hi Jim Thomerson, did you publish the article about alternative fuels used by the old control line guys..? I may have missed it, if so please direct me...thanks.
The reason I ask is that I search for additives to replace nitro in 4S engines and would like to know more about it. Have a couple of Saitos running fine on 0% nitro with onboard glow but my RCV.60 beats me...it absolutely NEEDS 10% nitro to run well.
In particular I search for real experience with ethanol as additive in 4S but have found little so far. Apparently it works fine for 2S even as the sole fuel.
Have read much about acetone but in my hands it gives no advantage when I add up to 5%. Lead free gasoline is the same - no better.
Revver Brother #84
(in reply to Rupurt)
       Post #: 11
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.641RCU1
