RE: Seaplane pictures
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Seaplanes >> RE: Seaplane pictures
Page: <<   < prev  6 7 8 9 10 11 [12] 13 14 15   next >   >>
Login
RE: Seaplane pictures - 1/9/2008 10:51:23 PM
Strykaas
Status: offline
Laddie,
Indeed I had not thought about the prop. Maybe there is some room for building a higher pylon ... Regarding the engine, today's .90 sized engines are roughly the same weight as .60 sized engines, so there is no actual reason to use lower displacement. Aircraft is big, it needs power for thoese windy days.
I know you've extensively used glow engines on your designs, especially the seaplanes. I now see that you have moved on to electrics.What is the main reason that has driven this ? Cost ? Airframe better life span (less oily mess) ? Cost ? Simplicity ? Glow engine tuning hassle ? You seem to have turned the page
_____________________________
ProBro #2077
http://image2-0.rcuniverse.com/e1/forum/upfiles/57402/Nl29490.jpg
(in reply to Goinstraightup)
       Post #: 276
RE: Seaplane pictures - 1/10/2008 10:39:33 AM
LADISLAV
Status: offline
Strykaas.
There are many reasons I moved to electrics. It started designing electric powered models sometime in late eighties as a challenge. I was approached by Easy Built Company to design electric powered models to compliment their line of rubber powered kits. They gave me everything needed to build electric powered models. I always dreamed to build multi engine planes. Now I could accomplish that with less hassle, using electrics. As a technology of electric propulsion advances, there is less and less reason to power the models with glow engines. At the moment, the initial cost of getting into serious electric stuff is higher then glow. Despite of that, I like no noise, clean model, easier installation of motors and no ugly muffler sticking out. At this time I have only one North Star powered by glow, rest is electric.
Laddie.
< Message edited by LADISLAV -- 1/10/2008 10:40:04 AM >
(in reply to Strykaas)
       Post #: 277
RE: Seaplane pictures - 1/10/2008 3:13:53 PM
AJ1202
Status: offline
Laddie your Shearwater is Beautifull. I wish you the best of luck on the maiden flight
I sure hope it fly's good for you.
Fantastic job on the build
AJ
Well I flew it up there... now how am I supposed to get it down
(in reply to LADISLAV)
       Post #: 278
RE: Seaplane pictures - 1/10/2008 11:25:49 PM
Strykaas
Status: offline
Laddie,
You' re quite right about electrics. There still remains a problem with them though : charge duration... It takes more than one hour to recharge these LiPO packs, and they're sometimes not that cheap, so having paris or more is difficult. I believe they'll improve in that area quite soon.
Keep us posted with your maiden
ProBro #2077
(in reply to AJ1202)
       Post #: 279
RE: Seaplane pictures - 1/16/2008 1:20:10 AM
mobilemenice80
Status: offline
here are some pictures of one of my balsa usa 1/3 scale cubs power is from a 3w 85cc c.s. twin[image][/image][image][/image]
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 280
RE: Seaplane pictures - 1/16/2008 4:00:16 AM
DLVS2FLY
Status: offline
Awesom looking Cub
DAVE ( COWMAN )
KEEP YOUR AIR SPEED UP
(in reply to mobilemenice80)
       Post #: 281
RE: Seaplane pictures - 1/16/2008 4:05:33 AM
DLVS2FLY
Status: offline
I also like your plan haulin wagon-----canoe too!!
DAVE ( COWMAN )
       Post #: 282
RE: Seaplane pictures - 1/23/2008 6:19:16 PM
jrf
Status: offline
Just ran across this photo of my Seawind on final approach. Photo by Michael Brown of the IMAA.
Jim
Click for fullsize
(in reply to DLVS2FLY)
       Post #: 283
RE: Seaplane pictures - 1/31/2008 12:11:13 PM
rawy
Status: offline
Martin Marlin P5M2 Depron Build from Philippe Jamet plans, powered by 2 Typhoons 6/3d with roxy 18 amps esc's.
1.35m Span, 472 g AUW with 4 Hitec 55's and 2s 800mah lipo and haevy but good looking 4 bladed Varioprops[image][/image]
Click for fullsize
(in reply to jrf)
       Post #: 284
RE: Seaplane pictures - 2/1/2008 4:58:24 AM
bigguyplanes
Status: offline
Great pictures,what kind of canoe ? is it, and how well does it work ?.
Aint no sound like big and round
       Post #: 285
RE: Seaplane pictures - 2/1/2008 8:00:49 AM
AlphaWhisky
Status: offline
Here`s mine - scratchbuilt about two years ago. I wanted a model that would work as a trainer, landplane, floatplane, camera plane, and maybe candy bomber. I labelled it 'VersaFli'
It is 70" span and was initially powered with an RCV 58. I just couldn`t get that engine to run well at all and have since replaced it with an old OS 60 FP. It is now a delight to fly off both water and land.
Construction is conventional balsa and plywood - covering is Ultracoat. Floats are foam core, sheathed with 1/16" balsa and then clad with fibreglass.
Alan W
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
From Tauranga - in the aptly named Bay of Plenty.
(in reply to bigguyplanes)
       Post #: 286
RE: Seaplane pictures - 2/6/2008 5:09:58 AM
mobilemenice80
Status: offline
the pics of my plane wit the cart were in the early stages...the plane now sits in a float cradle and is lashed to the cart...the boat is a small kayak (the kayak works great but honestly i have never had to use it to retreve a plane!(i know im gonna regret saying that!) it is also lashed to the cart... not show in the pic is a side rack that i made to hold the barn doors...eh er a the wings so that when i take the plane to lake other than my own i can make everything in one easy trip the cart really lets a plane of this size be practical i can get it to the lake and in most cases push the cart right in to the lake to launch the plane...we all know its more fun to fly with others but now i can do it myself if needed thanks for taking intrest in the cart it really is a fun set-up
       Post #: 287
RE: Seaplane pictures - 2/6/2008 6:33:42 PM
Airboatflyingship
Status: offline
quote:
ORIGINAL: LADISLAV
The scale model of New Zealand amphibious plane called SHEARWATER. The wingspan is 80”. Powered by AXI 4130/16. The flying weight is 9.5 Lbs. The wing is foam and rest is balsa. The model is ready to be flown. I will try to fly it from the snow first. Right now all the snow is melting.
Laddie.
Laddie that is another Beauty ................... congrats green with envy ................... have you flown her yet .................. re the cof g if it got desperate could you not use a short shaft to shift the motor forward?? It would negate the duct a little however.
       Post #: 288
RE: Seaplane pictures - 2/6/2008 11:13:55 PM
LADISLAV
Status: offline
I did not fly the model jet. As soon the runway at our club field is clear of snow and temperature is above freezing I will give it try.
(in reply to Airboatflyingship)
       Post #: 289
RE: Seaplane pictures - 2/7/2008 3:47:48 AM
Oh Yeah!!
Status: offline
Here's mine,
Just finished it up last week.
Phil
Thanks Guys for all the Help!!!!........
