sigrun
Joined: 7/18/2003 From: Dunnunda, AUSTRALIA Status: offline
Hi downunder Re BeNOL. Klotz publish an info spec. sheet listing the claimed properties of the product. They do state its lubricating properties and its flashpoint in qualitatively comparitive as well as quantitive terms. The ultimate test is of course the empirical. In two words, BeNOL does what they say it does. For us down under, its an expensive castor, though no dearer than synthetics. It is also difficult to source with any reliability locally. Re Castrol M. I can honestly only say I've been using it off and on for less than 15 years. I don't know what the castor was that I was buying as a teenager in the late 60's. As for Castrol M being degummed? The stuff coagulates everywhere, gumming internally and externally if an engine is left to sit unused for any time, and turns black when carb or bearing overspray is burnt onto the head or manifold leakage the exhaust. First press synonymous with degummed? I don't think so - or I'm surely victim to slick advertising? Possible? I'm not an industrial chemist so I'll double-check as is my wont. I did, perhaps mistakenly, think the degumming was achieved through a secondary separation process. Even the term "first press" is possibly misleading as the process itself is probably no longer mechanical but one of chemical and/or heat extraction? One thing I've discovered is for sure. Not only all oils, but all castors aren't equal. As for Castrol M? No thanks. A decent enough lubicant, but over-rated with no price advantage over synthetics any more and what a mess! Without getting into the trite old castor vs synthetic argument, for those of us who can tune an engine and prefer ringless tapered P&Ls, synthetics have been a boon. As for the use of intake air filters on aero engines, though understandably it's a pretty standard practice on RC cars, I only know of one(now two) of the several hundred aeromodellers I know who do fit them. Though not suggesting there's anything necessarily silly with the practice if you don't mind the decrease in power from the restriction of the mesh required for the filter to represent other than a rock strainer, numerically it makes you somewhat the oddity rather than as you infer, the other way around. I saw your post ref the Enya ring replacement in another post. Any problem getting the genuine spare? From Michael? Reasonable pricing?
