TT2
Joined: 3/19/2002 From: Osborn, MO, USA Status: offline
quote:
My question, which should be answered soon with an actual part, is, if you bag a foam wing with balsa, then glass it: 1. Do they vacuum bag the surface glass? 2. What kind of finish does the final layup (bagged or not) have? 1. Generally speaking, no. The surface glass is typically very light (0.7 oz-ish) glass that's either applied with epoxy (heavy) or polyurethane (water-based or solvent-based depending on your preferences). Then the surface is sanded, filled with more epoxy / polyurethane, sanded, filled, until the weave is completely filled. That being said, it might be possible to apply most of the glass at the same time as the balsa and save yourself some work. This would involve using 0.010 or 0.014 Mylar sheets to serve as 'carriers' for the lightweight glass. Essentially you would be creating a wing much like the way 'traditional', non-molded HLG (hand launch glider) wings are created with an extra layer of balsa between the glass and the foam. The mylars would be cut about 1/8" oversize of the wing core and then waxed. The light glass would be layed out on the mylars, trimmed slightly oversized, wet out with epoxy, then trimmed flush with the mylar's edges. Then the 'stack' would be created: - Mylar - Glass / epoxy - balsa - epoxy (or polyurethane glue) - foam core - epoxy (or polyurethane glue) - balsa - Glass / epoxy - Mylar Adjust the mylars to ensure that they are in the proper positon and then vacuum bag. The mylars could even be painted with primer before laying on the glass and save an additional step. I've bagged loads of HLG wings (glass/carbon/foam/carbon/glass) but have never tried the method above. I'm sure that some of the pylon racer guys have tried something like this before moving on to fully molded wings, so maybe one of them will chime in. This is a broad generalization and there are many process 'tweaks' to bagging wings like this...without the balsa. I don't see why it wouldn't work with the balsa. There would be a bit of secondary glassing around the LE, hingelines, etc., but I believe that it could still save you some time. I've done the polyurethane-ing, sanding, repeat-until-hell-freezes-over, and while it produces nice results, I have found it to be very time consuming. 2. The glass would show a little bit of the weave but the weave would disappear after one coat of primer / sanding. If the mylars had been primed before bagging the wings would be ready for the sanding / painting. -Tom
< Message edited by TT2 -- 2/17/2005 5:52:02 AM >
_____________________________
As complexity approaches infinity, mean time before failure approaches zero...
