Mr Terminator
Joined: 11/14/2007 From: Manchester, UNITED KINGDOM Status: offline
Tune the HSN to achieve the best possible top speed,then adjust the LSN for bottom and mid range,it sounds as if your battling with the wrong screw,once they are done then set your idle.Temps of around 240-260f are fine after WOT,don't just tune to temp.tune to sound and vision also,you can tell when an engine is on song and there should always be a smoke trail but not too heavy.You'll get there mate,I junked the SH engine in mine and got a LRP Z.28, after that it was amazingly reliable and crazt fast....
_____________________________
HPI Baja SS/Genesis LE/MG16MT/VRX-2 Pro/HB Lightning GTX2/NB16T/Micro T.
