mixer for old AM futaba tx
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Combat >> mixer for old AM futaba tx Page: [1]
Login
mixer for old AM futaba tx - 11/18/2004 6:10:48 PM
twister55
Status: offline
Hi
I want to fly combat gremlins.
I have an old futaba attack 4 channel radio.
Can I get a mixer for these older radio type such as the GP or gws type mixers that work for AM band servos?
If so were and which kind
       Post #: 1
RE: mixer for old AM futaba tx - 11/18/2004 9:01:36 PM
Montague
Status: offline
Servos are servos, there is no such thing as an "AM" servo. The signal from the RX to the servo is the same for all of them, regardless of the signal from the TX to the RX.
So, if GWS makes an elevon mixer box that plugs in between the RX and the servos, it should work fine.
_____________________________
Kirk Montague Adams
RCCA 560
(in reply to twister55)
       Post #: 2
RE: mixer for old AM futaba tx - 11/18/2004 11:00:00 PM
erik58
Status: offline
I used that same radio on a gremlin I used a tray you put one servo on a mount thats on a slider that s for the the ailerons and the other slides the servo for elevator.make it with nylon snakes with blocks of wood for the mounts and put blocks inside it for the slide. Ihope I was clear in my explansion good luck Erik
(in reply to Montague)
       Post #: 3
RE: mixer for old AM futaba tx - 12/7/2004 10:26:03 PM
Live Wire
Status: offline
Why not use a Y harness!!!!!!!!!
Larry K AMA 36417
WACO Brotherhood #34
(in reply to erik58)
       Post #: 4
RE: mixer for old AM futaba tx - 12/7/2004 10:39:19 PM
Montague
Status: offline
Because it won't work.
Gremlins use elevons, not just duel aileron servos.
Kirk Montague Adams
RCCA 560
(in reply to Live Wire)
       Post #: 5
RE: mixer for old AM futaba tx - 2/9/2005 6:37:42 PM
BrykMantis
Status: offline
ACE has the SimpleMix which would be perfect. I use it in a RAZOR and in a V-BAT.
FMA also has a mixer.
In both, all you do is plug in the servos in one end and plug the other ends into the receiver aileron and elevator channels. Easy, no need for a computer radio.
Casabryk
Learn from the mistakes of others. You won't live long enough to make all of them yourself.
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.813RCU2
