Just a lil tip for use faom and compisite guys
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Composites Fabrication And Repair >> Just a lil tip for use faom and compisite guys
Page: [1]
Login
Just a lil tip for use faom and compisite guys - 11/19/2004 5:06:36 PM
xplayer930
Status: offline
Well we all cut foam with a hot knife, but some times can always find the michrome wire. Well if your out of luck with the michrome, u can jsut go to the local music store an pick up some gutar string. Works excelent, and doesnt really break, even if it is forced threw the foam.
       Post #: 1
RE: Just a lil tip for use faom and compisite guys - 11/19/2004 11:12:06 PM
checksix
Status: offline
i thenk yew ned a spel cheeker
(in reply to xplayer930)
       Post #: 2
RE: Just a lil tip for use faom and compisite guys - 11/20/2004 2:47:55 AM
vicman
Status: online
Please resist the urge to curse, flame, degrade, insult or embarrass someone in your post. We encourage the free flow of your ideas, but believe that they can be communicated (and received) much more effectively if you keep things civil. If you have to vent, take it offline. We carefully monitor posts and will ban individuals who engage in offensive conduct within the forums. Thanks.
Play nice dude
_____________________________
Bigger Badder Meaner Faster!
Revver Brotherhood & NMPRA #41
(in reply to checksix)
       Post #: 3
RE: Just a lil tip for use faom and compisite guys - 11/20/2004 11:35:20 PM
F3A1
Status: offline
xplayer930
Thanks for the tip. It sounds like it will work great!
Lex
"An ego is no match for gravity"
(in reply to vicman)
       Post #: 4
RE: Just a lil tip for use faom and compisite guys - 11/22/2004 5:30:01 PM
xplayer930
Status: offline
hey when ur pressed for time and u gotta go theres no time for spell check
(in reply to F3A1)
       Post #: 5
RE: Just a lil tip for use faom and compisite guys - 11/25/2004 5:59:57 AM
scarfaced
Status: offline
I had a hard time finding the nichrome wire too, couldn't straighten out the toaster element either, so I used the stainless steal wire for control line planes. there is 2 super long wires for 20 bucks canadian. I have cut about 20 wings with no breakage.
       Post #: 6
RE: Just a lil tip for use faom and compisite guys - 11/25/2004 7:55:55 PM
XJet
Status: offline
Other sources for wire that can be used in a foam-cutter are:
1. Stainless steel welding wire (MIG) which can be had down to 0.6mm (0.024" or less.
2. Stainless steel aircraft safety wire
The MIG wire is usually at least half-hard (ie: quite stiff) but the safety wire is annealed (very soft).
The advantage of using both of these is that they're slightly thicker than most nichrome wire which means you can operate them under quite a bit more tension -- and that makes for a more accurate cut -- although they do require a little more current.
(in reply to scarfaced)
       Post #: 7
RE: Just a lil tip for use faom and compisite guys - 11/25/2004 9:51:50 PM
nIgHthAwK17
Status: offline
0.004" tungsten wire works wonders at the right tension and temperature - an almost non-existant kerf!
Ad Astra Per Aspera
       Post #: 8
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.484RCU1
