rrritchey
AZ, USA Status: offline
Bill, Answering this question depends a lot on the type of battery you are running. If you are running 5-cell packs (NiCd or NiMH) then you can pretty much go simple by doubling everything up to the receiver and run this unregulated. The only danger you run here is if somewhere along one of the power paths you end up with a real short, positive to negative, such as insulation wearing through. This is unlikely compared to a battery going dead. Some people experience servo "chatter" on a 5-cell full charge and the BatShare will help with this. Now, if you are going to run lithiums (ion or poly) you have a completely different situation. You have to run a regulator. You may, mostly likely will, run into a problem where if you hook the two regulator outputs together at the receiver, one side is going to supply most of the current and one battery will discharge much faster than the other. There is no good way to "match" regulators, this is just their nature. So, running lithiums, you are pretty much going to be stuck going through one regulator if you are running a single receiver. This ruins your redundancy but regulators (quality ones) are much, much less likely to fail than a battery pack or switch. I think this should get you started, let me know where I can expand on this answer.
_____________________________
Robert Ritchey Owner, Smart-Fly
