RE: Who has Built & Flown a SIG Bonanza?
Tower Hobbies
Logged in as Guest
  Printable Version
Premier Pilot 1/4 scale full body pilot
Seller:  Ren DiLeo
Details:   $99.00   |  9/21/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Scale Aircraft >> RE: Who has Built & Flown a SIG Bonanza?
Page: <<   < prev  1 2 [3] 4   next >   >>
Login
RE: Who has Built & Flown a SIG Bonanza? - 9/30/2007 7:38:43 AM
PilotFighter
Status: online
more paint
Click to see fullsize image.
Click for fullsize
_____________________________
turn left, your other left
(in reply to PilotFighter)
       Post #: 51
RE: Who has Built & Flown a SIG Bonanza? - 10/5/2007 6:35:14 PM
Maki
Status: offline
Very Nice work PilotFighter, please keep posting you work.
Well I received the mechanical retracts from Robart, so I'm starting to fit them oh the wing:
Using Robart Struts it looks nice:
now, lets go on with the other wing....
       Post #: 52
RE: Who has Built & Flown a SIG Bonanza? - 11/14/2007 9:35:17 PM
PilotFighter
Status: online
Nice work, Maki. That is going to be sweet! Well, here is some of the glacial progress at my house. Got a radio, just need the time now. I was going for an old-school, vintage look.
PS. I hear Santiago is beautiful !!!
Click for fullsize
< Message edited by PilotFighter -- 11/14/2007 9:38:02 PM >
(in reply to Maki)
       Post #: 53
RE: Who has Built & Flown a SIG Bonanza? - 11/15/2007 1:57:16 PM
Maki
Status: offline
Pilotfighter, very very nice look of your Plane, I hope mine will look like yours.
I have some questions maybe you can help me, on posts behind you write that you used "Nitrate Dope and Dacron" what are this two products ?, and you used this products right over the balsa wood?, and as last question , you don't used fiberglass to cover the plane?
Thank a lot for you help and nice flyings,
Mario
(in reply to TLH101)
       Post #: 54
RE: Who has Built & Flown a SIG Bonanza? - 11/15/2007 8:44:34 PM
PilotFighter
Status: online
Nitrate dope and Dacron are both sold by Sig. Dacron is called Koverall by sig, but its really the same Dacron that is used to cover real airplanes, just a lighter, thinner version. So look for Sig Koverall. I used dope and Koverall on the fuselage. I was afraid that fiberglass would be too heavy. I thought this plane wan't big enough for fiberglass. And I am kind of alergic to it. It turns out, that I really love the Koverall and dope technique. Its very old school and easy.
First, sand the fuselage smooth with 400 paper. Then apply a coat of clear nitrate dope. (just on the wood part) I cut it with Sig dope thinner until it was almost as thin as water. It dried in about 30 minutes. Sand with 400 paper. Apply another coat of dope. Sand. Then paint it with Sig stick-it. Thats the adhesive. The plain dacron has no adhesive of its own. Then iron on the Koverall. Then paint it with 2 or 3 more coats of thinned dope. Sand between coats. Then use what ever finish you like. I used auto primer, then Lusterkote paint and Rustoleum paint. Then shot Lustrekote clear. I covered the wing and tail with Monokote, thinking that would help keep the wieght down.
If I had to do it over again, I would have covered the entire plane with Koverall and dope and painted it. The patina of paint looks more realistic than the plastic mylar film. ANd I used rattle-can paints. You could get a much better finish with a spray gun and some of the nicers paints like Glasscote. Maybe next project.
If you are good with fiberglass, then you should probably stick with what you know. This plane can be finished up very nicely. I did alot of experimenting of this project and I feel as though I was lucky to get the results that I got. I had to test several paints for compatability and reactions.
(in reply to Maki)
       Post #: 55
RE: Who has Built & Flown a SIG Bonanza? - 11/19/2007 2:18:45 PM
Maki
Status: offline
Thank you very much Pilotfighter for this clear step-by-step instructions, I only need to know if you applied the nitrate dope with a simple brush or with a airbrush, I'm not familiar with fiberglass so I will follow you techique, because the finish looks really great.
thank you very much again and nice weekends.
Mario
       Post #: 56
RE: Who has Built & Flown a SIG Bonanza? - 11/19/2007 9:14:17 PM
PilotFighter
Status: online
Thats the beauty of the dope and fabric, you can use a brush. I got one at the hardware store, about 1 inch wide. I did buy a pretty nice brush. I don't know if it was horse hair, but it was certainly softer than nylon.
(in reply to Maki)
       Post #: 57
RE: Who has Built & Flown a SIG Bonanza? - 11/20/2007 12:28:05 PM
Maki
Status: offline
Thanks Pilotfighter, I have already identified the NItrate Dope and Koverall on Sig's webpage, but I can not find the "Sig stick-it", do you have a picture of this glue? or the link where I can find it?
Thanks a lot and best regards,
Mario
       Post #: 58
RE: Who has Built & Flown a SIG Bonanza? - 11/21/2007 12:25:58 AM
PilotFighter
Status: online
Man, your right. I can't find it either. Its spelled Stix-it. I checked the can and Sig does make it. I fired off an email to them asking where it is on the site. You also need dope thinner. when I read the discription of Koverall, it even says to use Sig Stix-it. Then it says (see below). But its not listed below. Might just be a programming oversight. We'll see.
(in reply to Maki)
       Post #: 59
RE: Who has Built & Flown a SIG Bonanza? - 11/21/2007 11:09:35 AM
Maki
Status: offline
Pilotfighter, I have identified all the products:
The Koverall:
The Stix-It:
And the Thinner for the dope:
I allready asked to a Chilean dealer to import it for me, I hope to have the product in two weeks at home, the Nitrate Dope is able to find in a RC local store, so I'm very happy, thank's for you support Pilotfighter.
Regards,
Mario
       Post #: 60
RE: Who has Built & Flown a SIG Bonanza? - 11/21/2007 6:46:13 PM
PilotFighter
Status: online
OK, good. Sig emailed me back and said they still have Stix-it in good supply. But they didn't say how to find it on the website.
(in reply to Maki)
       Post #: 61
RE: Who has Built & Flown a SIG Bonanza? - 11/24/2007 10:19:00 PM
Ronny Hightower
Status: offline
I have a sig bonanza that was bought new in the 70s and I never put it together. Over the years I have lost the wings but I still have all the rest of the kit and the plans. I have been looking for wings or at least plans that would allow me to scratch build them. If I can make you some copies of something let me know. My email is ronny_hightower@yahoo.com
(in reply to uglyflyer)
       Post #: 62
RE: Who has Built & Flown a SIG Bonanza? - 11/25/2007 12:54:55 AM
TLH101
Status: offline
Dynamic Balsa lists the foam wing cores for the SIG Bonanaza wing on their site. Part# W4003, they also list cores for the stab.
http://www.dbalsa.com/
Terry
"Old Fart" in training. (not to be an R/Cer, but to be an "Old Fart")
(in reply to Ronny Hightower)
       Post #: 63
RE: Who has Built & Flown a SIG Bonanza? - 4/6/2008 3:28:41 AM
PilotFighter
Status: online
I know, I know. How is it possible that I am still building that same Bonanza after all of this time. Hint : (I'm really more of a flyer)
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 64
RE: Who has Built & Flown a SIG Bonanza? - 4/8/2008 12:33:30 PM
GRANT ED
