Walter D
CA, USA Status: offline
I built two of these back in the '70s, great looking and flying airplane, a good .60 2 stroke flies it fine. I built them with the V tail configuration and they were still tail heavy, so I would plan for a built up stab and fin, or just lighten up the sheet stock they provide for tail surfaces by cutting up holes, while maintaining the airfoil shape, of course. The plastic upper fuselage can be glued to the lower wooden side by using a good aliphatic glue to be used with plastics and/or wood or slow curing CA. I would first build the model and once everything is in place, see how it balances, then decide if it will take fiberglass and resin on the plastic upper fuselage, because it might make it very tail heavy, and there are no loads imposed on that part of the fuselage anyway that would call for that type of finish. I built mine with flaps and retracts, total weight of 9 lbs, the wings were covered with thin cardboard and then painted, fuselage was glassed (not the plastic part) and painted, this airplane flies like a pattern ship, is very fast so to slow it down on landing the use of flaps was a very welcome addition.
