RC Accessory
Joined: 12/7/2001 From: Tampa, FL, USA Status: offline
I have to agree, Ace is crap. No offense to anyone. I had their Digipace II. The unit was off by 10% on the charge rates and the voltage cut off after cycle was way off too. The cut of voltage was adjustable by a pot inside the unit. The charge rate was not. I contacted Ace and told them the problem. They said that was normal and that their tolerance was 10%. 10% tolerance on electronics! That is outrageous. Tolerances on electronics is usually less than 1% accuracy. Once I new the real #'s, I was able to make my own calculations. Peak Electronics makes some nice units, but I think they missed the mark too. The Limited is a great unit, but is limited to 6 cells. Can't do my tx packs. The perfect charger would be the Super Nova 250S with 2 fully independant ports. Unless you're charging electric plane batteries, we do not need 5 amp charge rate as well as the ability to charge 25 cells. Or the Alpha 4 with a 2 amp charge rate per port. Either way, neither unit exists or is cost effective to have in 1 unit. I personally use 3 chargers. An Alpha 4, a Super Nova 250S, and a Hobbico Multi-port charger. The Multi-port charger is used to keep batteries on trickle. I just set the charge rate as close as possible to the trickle rate for the particular battery. The smallest battery I use is an 1100 4 cell nicad while the largest is a 5 cell 2700 Nimh.
