New: Eflite Mini Funtana
Tower Hobbies
Logged in as Guest
  Printable Version
More Resources on the
Mini Funtana - EP
  • 1 Active Classified Ad(s)
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • Discussions on this Product
  • All Forums >> Electric Aircraft Universe >> 3D Electric Flying! >> New: Eflite Mini Funtana
    Page: [1] 2 3 4 5 6 7 8 9 10   next >   >>
    Login
    New: Eflite Mini Funtana - 11/29/2004 10:41:42 PM
    scottm
    Status: offline
    This looks great, I can hardly wait for it to come out! Does anyone have any dirt on this puppy?
    http://www.horizonhobby.com/Shop/ByCategory/Product/Default.aspx?ProdID=EFL2075
    _____________________________
    I spend most of my money on beer, women, and R/C. The rest I just waste.
           Post #: 1
    RE: New: Eflite Mini Funtana - 12/8/2004 11:37:24 PM
    LarryC
    Status: offline
    it is going to have 2 places to put the wing
    that might be fun
    (in reply to scottm)
           Post #: 2
    RE: New: Eflite Mini Funtana - 12/9/2004 2:59:00 PM
    SMALLFLY-
    Status: offline
    Has anyone else noticed this full size fuse plane at 37" is supposed to weigh only 20 oz.... No way. My 36" purpose built electric e taco weighs 28 oz all up with 2500 ma batt and its a very light profile.
    < Message edited by SMALLFLY- -- 12/10/2004 12:52:20 PM >
    Big Fish in a Small Pond
    (in reply to LarryC)
           Post #: 3
    RE: New: Eflite Mini Funtana - 12/9/2004 5:32:50 PM
    Jason W M
    Status: offline
    Actually, I've been flying a production sample Mini Funtana for a few months now and a number of prototypes have been flown in the past 6 months. With the included gearbox (6.6:1 ratio), 12x6 prop, E-flite Park 400 4200kv motor, Thunder Power 3S 2100 10-12C capable pack, Phoenix 25 ESC, 4 JR 241 servos and a JR610M receiver the weight is just under 25 ounces ready to fly. This is the recommended motor combo and performance is awesome. Current draw is around 21-22 amps on a fully charge pack, producing close to 40 ounces of thrust. On a 25 ounce airplane, this is incredible vertical performance capable of all the 3D manuevers you can think of.
    The Mini Funtana was demoed at SEFF this year and more recently at the JR Indoor Festival where everyone was very impressed with the power and performance. You can see a video of the Mini Funtana being flown by Mike McConville with the recommended motor set up here:
    http://kepople.rchomepage.com/images/funtanamini.wmv
    We should be updating the web page specs very soon - it should be around 20 ounces RTF less battery. The first batch of Mini Funtanas should in stock at your favorite local shop just before Christmas!
    Jason Merkle
    E-flite Product Manager
    Horizon Hobby
    (in reply to SMALLFLY-)
           Post #: 4
    RE: New: Eflite Mini Funtana - 12/9/2004 9:13:14 PM
    SMALLFLY-
    Status: offline
    You should advertise your weights noting less battery. Isnt pushing 22 amps thru a 180 watt class motor a bit much?
    (in reply to Jason W M)
           Post #: 5
    RE: New: Eflite Mini Funtana - 12/10/2004 1:21:19 AM
    RiffRaff
    Status: offline
    I really want one of these things! I am going to put in my order this weekend!
    I have an AXI 2212/20 with a Jeti 18 amp waiting for a plane now since I just lost the current ship yesterday to a radio failure. It was an Air Blaster.
    Will this motor combo be okay for this Mini Funtana? If so, should I direct drive it or use the gearbox?
    Riff
           Post #: 6
    RE: New: Eflite Mini Funtana - 12/10/2004 9:24:46 PM
    Jason W M
    Status: offline
    Riff -
    I dont have direct experience with the 2212/20 motor, but have flown the 2212/34 motor quite a bit. While the 2212 series motors are excellent for powering 3D models 16-18 ounces, it might be a tad bit less power than you'd like on the Mini Funtana for all out 3D performance. I believe one of the 2808 series motors might be a good fit, but have not tried one myself.
    The included gearbox readily accepts our Park 400 brushless motors which sell for under $55 most places and provide outstanding performance. Yes SMALLFLY, 22 amps can be too much power for these Park 400 class of motors without proper cooling and throttle management. An add-on heatsink will soon be available for the Park 400 motors which will aid in cooling (cut outs have been included in the cowling to increase airflow), but use of the 4200kv motor for all out 3D flying will still require proper throttle management to keep the motor temperature under control. As you will find in the manual (now posted on our site), we do cover this. Using the 3700kv motor, max current is around 18 amps, which still provides good vertical performance while keeping the duration up and motor temps down. I assure you, both motor set ups were extensively flight tested in extreme conditions (that day the video was shot it was over 90 degrees with 90%+ humidity and the motor performed very well) and with proper cooling and throttle management they both worked great.
    As noted in my first post, we will update the weight on the web as soon as possible (it has already been corrected in recent print materials).
    Jason Merkle
    Horizon Hobby
    (in reply to RiffRaff)
           Post #: 7
    RE: New: Eflite Mini Funtana - 12/11/2004 2:25:18 AM
    DrFun
    Status: offline
    is E-flite Park 400 4200kv comparable to Himax 2025-4200 ?
    Former RCU Id: Cobra78
           Post #: 8
    RE: New: Eflite Mini Funtana - 12/15/2004 9:33:07 PM
    blue ice
    Status: offline
    Will my himax 2015-4100 fly the Funtana?
           Post #: 9
    RE: New: Eflite Mini Funtana - 12/16/2004 12:38:46 AM
    flip3d454
    Status: offline
    it might fly it but will be very heavy on the sticks.
    flip
    life is simple
    eat sleep FLY 3-D
    (in reply to blue ice)
           Post #: 10
    RE: New: Eflite Mini Funtana - 12/16/2004 2:38:06 AM
    y2ohoh
    Status: offline
    mines ordered have the 40 size now this is the best flying plane I've flown so far and if the mini is half as good i cant wait
    I'm going with the kontronic fun 400 Phoenix 35
    (in reply to flip3d454)
           Post #: 11
    RE: New: Eflite Mini Funtana - 12/23/2004 7:25:19 AM
    Rc_InTheBlood
    Status: offline
    I just started with the electric planes and went out and got cap 232 wattage for starters.i put a little bit bigger servos then what it calls for ...Does it really matter???
    (in reply to y2ohoh)
           Post #: 12
    RE: New: Eflite Mini Funtana - 12/23/2004 3:10:41 PM
    airbornrc
    Status: offline
    I couldn't wait for my park 400 motor to show up so I put a himax 2015-4100 that was laying around in my funtana with a Thunder power 1350 three cell. It turns the 12-6 pretty good. It will just hover at full throttle. The plane flies like a scale aerobatic plane with this set up but not a 3-d plane. the motor gets pretty warm if you push it. My park 400, speed control and batteries showed up at the hobby shop yesterday and are going in tonight! Can't wait. This is a great flying and beutifully made airplane.
    Mark
    Mark Anderson
    (in reply to Rc_InTheBlood)
           Post #: 13
    RE: New: Eflite Mini Funtana - 12/24/2004 12:02:28 AM
    luv2fly2
    Status: offline
    Will the Jeti speed control 18-3p work with the eflight 400 for this plane? I have it setting here new, and would like to know before I used it.
    (in reply to airbornrc)
           Post #: 14
    RE: New: Eflite Mini Funtana - 12/24/2004 2:23:42 AM
