AndyW
Joined: 1/17/2003 From: Timmins, ON, CANADA Status: offline
I've been running Norvels converted to diesel and they perform very well. At first, I had trouble with the 1/3rd formula. That is, 1/3rd ether, kerosene and oil with 2% amyl nitrate. Eventually, I stumbled on the fact that MEKP works great. Also, 33.33% oil in modern engines is NOT required. As well, John Deere quick start is 80% ether and works perfectly. Oil is Sig AA castor or Klotz Benol. Formula: Ether 30% kero 50% oil 20% MEKP 2% Yes, this adds up to 102% but hey that just means you get that much more fuel. :0) Kidding aside, the numbers used are to make it simpler to understand. I've run this formula on engines from .049, .061, .074, .15 Norvels and an Enya11CX converted. All start easily with a starter, run strong and throttle well. All the Norvels have been flown extensively, winter and summer, no bent rods or busted cranks. The key is to make sure your compression setting is right on the money, your needle is set and you apply just THREE drops of prime into the INTAKE and NEVER the exhaust. Hit it with your starter and she should fire off. If not, your line to the carb was not full but the first prime run ought to have done the trick and the next prime should get you running. I've even been so brave as to choke the throttle while applying the starter. Works if careful, no busted parts yet. BTW, No jelling in winter with hardware store kerosene. Mind you, this is at just above or just below freezing.
< Message edited by 1705493-Andy -- 12/26/2004 1:32:37 PM >
_____________________________
Andy Woitowicz
