ghost123uk
Joined: 11/29/2004 From: Chester, UNITED KINGDOM Status: offline
quote:
ORIGINAL: sajjad I have used and made my own Diesel fuel for a long time. I used one part of each - Ether Anaesthetic, Kerosene Oil and any common motor oil. (5W30 etc) A little more Ether makes starting easier and is recommended but I never had any problems with the one part each ratios. In case you need to store the fuel for a long time, add a little more Ether. Amyl Nitrate is not necessary but may be used. Avoid medicinal Castor oil as it will break up under compression and cause excess engine wear. Ether is available from stores that supply Laboratories and Hospitals. Use it in a ventilated area only. With the greatest respect sajjad, most engine manufactures (PAW, ST, Olly T, etc etc) say do not use common motor oil as it is not designed to be burnt, as happens in a 2 stroke motor. Amy Nitrate or IPN etc is required for any high performance motor to make it run smooth and produce the power the makers designed into it. Re Castor oil, I believe medicinal castor is fine, tho I now use motor racing Castor, for over 20 years I used medicinal Castor in my PAW's (plain bearing and BR's) ST's etc, and have never had to replace any moving parts in any of them. Here in the UK Anaesthetic Ether would be very expensive, we use "solvent grade" Ether, just fine The following is snipped from the PAW site at = http://www.progress.charitydays.co.uk/instruct.htm 14. HOME MIXED FUELS (mix oil-ether-paraffin and additive) ** Mix fuel outdoors - Take all necessary precautions - No naked lights ** Castor Oil Paraffin Ether Iso Propyl Nitrate or similar ignition improver Running in Castor Oil 30% Paraffin 35% Ether 33% Iso Propyl Nitrate or similar ignition improver 2% Fully run in Castor Oil 25% Parafin 40% Ether 33% Iso Propyl Nitrate or similar ignition improver 2% Fully run in - BR Models Castor Oil 20% Parafin 48% Ether 30% Iso Propyl Nitrate or similar ignition improver 2% Fully run in- TBR only (Racing and Speed) Castor Oil 15% Parafin 50% Ether 32-33% Iso Propyl Nitrate or similar ignition improver 2-3% End snip - JB I agree though that on a large, mild, converted glow motor, (as this post started with !!) turning a big prop, your brew will work ok. Where in our world are you my friend ?
_____________________________
JB in N.W. UK - (if you are into control line in my area, get in touch - we have a good scene going these days :) )
